Question about Navigon 2100 Portable GPS Receiver
Need fuse replacement
Do you know the rating / specification of the fuse you used to replace the original one? My fuse is broken and I need to buy a replacement
Fuse 5S2A 250V FUSE:2:0A
Exclusive use for only 12V negative ground electrical systems, this is of the lable on the charger, i am still looking for a supplier for the fuse.
Posted on Jul 23, 2009
What thermal fuse do i need for an 800 watt 10amp food dehdrater? heater quit working.
An 800 watt appliance consumes just over three amps with maybe a surge on switch-on but a thermal fuse isn't primarily rated in amps but in degrees (temperature).
The temperature of the replacement fuse should be identical to the original - usually marked on the body. If the original marking has disappeared you will need to use an educated guess or draw on the experience of an appliance engineer if the appliance specifications aren't available.
Dec 27, 2016 | Cars & Trucks
Vitamix 3600 manual
Get a switch with the same or higher voltage and current rating, and similar mounting and terminal connections. If you can't find the rating on the switch itself, use the nameplate rating on the appliance label.
Once you have these numbers, go to the Carling Tech toggle switch page and drill down through the selections to identify what you need. Toggle Switches
May 12, 2014 | Blenders
Lost all electrical after replacing fuse
When replacing the fuse must be consistent with the original fuse specification, cannot arbitrarily increase the current rating of the fuse, cannot use other conductive objects instead of more. If change to once again blow a fuse, circuit fault has occurred, should ask professional troubleshooting again after mount fuse, must not with increasing fuse specification to deal with, or is likely to cause a fire.auto diagnostic tool
Apr 05, 2013 | Cars & Trucks
I have a confidence powerplus motorized teadmill. I need to replace the glass fuse in the circuit board, what size and rating should it be?
you must read the same fuse in the metal part, the specification, normally will be 15amp, 240VAC, However confirm with the indication printing specification in the same fuse, You can buy from R. schak or another electronic store.
God bless you
Dec 12, 2012 | Confidence Power Plus Motorized Electric...
The fuse box under the hood, one of the fuse insert is broke so I need to replace the whole box. I need help to find the part ant the name of the part
You can call it a fuse box or panel. The unit usually comes as part of the harness. You can usually find a good used unit in most scrapyards or, you can make a "work around" by detaching the box and locating the wiring that feeds and is served the broken fuse holder. Then, all you need to do is buy an in-line fuse holder and bypass the original by attaching the wires from the holder to the backside of the panel. Use one rated at or above whatever the fuse you are replacing and use the same fuse that belongs there. If you do this, the only caution is to make sure you don't pinch any wires when you put it back together. It sounds complicated but it's far easier than installing a complete unit and it shouldn't cost you more than $10.00.
May 11, 2011 | 1996 Jeep Grand Cherokee
How to fix original xbox red eye
This is a very difficult problem to replace. Your problem can mean two things:
  1. A part has overheated and broken.
  2. Your xbox needs to cool down.
To deal with the first issue you will need to find the specific part such as the motherboard online and then replace it.
For the second issue, find a well ventilated environment. You could also buy an xbox fan to cool down the system. Although, there are no guarantees on the solutions to the second issue.
Apr 29, 2011 | Microsoft Xbox Console
I need to know the amp size of fuse to replace on AKAI LCT2662. thanks
If you have the original fuse, it's the number stamped on one of the end caps after the three letters denoting the fuse type. Most manufacturers also print the fuse rating on the power supply circuit board ("Caution: replace fuse only with...")
I have one of these sets in the shop now, but I haven't opened it yet. Post a reply if you can't find the fuse type and rating, and I'll let you know what my project uses.
I assume you already know fuses in TV sets don't blow by themselves, but indicate another part is shorted. Check the diodes, transistors and power ICs in the power supply before plugging the set in. If you see any bad capacitors, fix those also.
Sep 28, 2010 | Akai LCT2662 Television
Horn fuse blowing out ,i already changed it for a new one,the same rate 15a,and it still blowing out"broken",i know there is a short shot somewhere but i don't have the electrical wiring map to follow it...
Try putting a 20a fuse in it . if it blows, call a pontiac dealer and ask to speak with a technician. You can also buy a chilton or online repair manual at mitchel 1.com to get a diagram. The horn may need to be replaced.
Mar 11, 2010 | 1997 Pontiac Grand Prix
My TV model CT-36HL42CF,the power switch (on-off) doesn't work
Is the button broken? More likely, the thermistor and main fuse need replaced. The fuse should be upgraded to a 7 amp GMA.
Dec 15, 2008 | Panasonic Televison & Video
Navigon 2100 Portable GPS Receiver Logo
438 people viewed this question
Top Navigon GPS Experts
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
