Question about Rowenta DG-980 Iron
Rowenta DX-9800 Perfect Steam Ironthe problem is not working anymore, just yellow light is on!
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
wizzard8955
  • 18 Answers
SOURCE: My Rowenta iron will not heat up. The yellow light
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Posted on Mar 06, 2009
SOURCE: new rowenta effective iron that doesn't heat and steam correctly
Don't use distilled water-I had same problem. It was built to use regular water. Solved problem
Posted on Mar 08, 2009
heatman101
  • 43501 Answers
SOURCE: I have a rowenta advancer DZ9080 iron that the
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
The tank in my rowenta iron is producing steam but the iron is not producing steam
Yes the iron needs to be cleaned. They do have a descaler to clean. the Steam valve with a electronic switch is broken, that is what opens and lets the steam out of the iron when you press the button.
Google Rowenta repair Centers.
Jun 30, 2014 | Rowenta DG5030 Iron
Issues with Rowenta Steam Iron DG 05030 steam hose
Does your iron have a self cleaning feature? It sounds to me like you have calcium build up and when you squeeze the hose it displaces the "clog" just enough to allow steam through.
Nov 12, 2012 | Rowenta Steam Generator DG050 Iron
My Steam Iron Rowenta dx1700 leaks on my clothes and turns itself off while I am ironong. I am ready to chuck it.
My brand new DX1700 iron leaks. Why is it leaking. I had a Rowenta Professional for 17 years and it never leaked. What do I need to do.
Jan 12, 2011 | Rowenta Perfect Iron
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
My rowenta effective will not heat up.
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Dec 15, 2008 | Rowenta DG5030 Iron
Rowenta steam generator
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Aug 27, 2008 | Rowenta Steam Generator DG050 Iron
Steam Button
Your iron pump is faulty the high pitched sound is normal.
Rdgs
Alan
Nov 27, 2007 | Rowenta Perfect Iron
Rowenta DG-980 Iron Logo
165 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
