Question about Proform Crosswalk 500 Treadmill
Need replacement key
I have an Athletech performance treadmill and my dog ate the key!! Where can I get a replacement Key? SN007184A
I ordered a key from the treadmill doctor site. It cost me 9.99 free shipping. I ordered the 1" Safety key for Proform & Weslo Treadmills 119038. It was a little thick so I sanded the rails on the bottom with a soft Kiss lady's nail sander. I only left a small smidgen of the rails on the key. Now it works just fine. The clothing clip is not as nice as the orginal, but is sufficient.
Posted on Nov 27, 2010
Tip
How to calibrate a Vision Fitness Treadmill - Residential Models
If you are not quite sure about the speed/elevation of your machine you can perform the following to test/correct your Vision Fitness treadmill.
1. Remove safety key and then replace
2. Hold the elevation up and speed down buttons until it beeps 3 times
3. If you see the model of your treadmill on this screen make sure you hold enter and then you will see "eng1"
4. Use the elevation buttons to scroll to "eng4" and hold enter to select
5. you should see the word "auto" on the screen at this point
6. Making sure you are not on the treadmill at all, press start.
The treadmill will go through a few tests to determine the maximum and minimum of both speed/elevation. You can see the results on the display as it is performing this test and if there are any discrepancies the machine will adjust the settings to make the appropriate speed/elevation calibration.
If the test passes it will display "end" and from here just remove and replace the safety key. You should notice a difference in the speed right away.
on Aug 05, 2010 | Exercise & Fitness
How to softwhere reset GTX75 airtyme torrid mobile
Try this: The web interface offers a simple way to reset to factory defaults. It is necessary to login to the phone`s admin account to perform a full reset. Go to the "Advanced" screen. Click on "Factory Reset" then "Submit" and "Reboot phone". Early manufactured phones can be reset to factory defaults, including admin and user passwords, using the undocumented ATE menu feature. 1) Invoke the ATE menu and wait for the "Func No:" prompt. 2) Enter 37 and press the green key. Wait for "Success" and press red key. 3) Enter 38 and press the green key. Wait for "Success" and press red key. 4) Enter 41 (=Clear User Data) and press the green key. Wait for "Success" and press red key. 5) Turn the phone off and back on - it should be totally cleared and the default passwords will be set. WARNING: Performing the ATE reset will also clear the phonebook entries and all user-specific settings.
Apr 16, 2016 | Cell Phones
Safety key
Check here for guidance on how replace or repair your safety key:
http://www.partsfortreadmill.com/parts-for-treadmill/treadmill-safety-key/
http://www.treadmillsrepair.co.uk/2014/08/treadmill-safety-key.html
Jul 22, 2013 | Merit Fitness 725T Treadmill
I have an athletech performance treadmill it won't turn on on button doesn't click as does the off button
Dear Sir:
1) Try to reset the c. breaker in your treadmill.
2) Inspect if your see some loose wires.
3) Open the keypanel and tight the flexible cord or ribbon cables.
4) Tight the connector coming from display planer to lower boar or main motor board.
5)Test the Transformer for there are voltage in primary and secondary winding.
6) Measure the input to the power board
7)See there are +5VDC to the main motor board and display board?
8) Run the calibration Software read your user manual or see under the Hood the motor the instruction for more easy diagnose and troubleshooting . Attached is my block diagram that I did design for purpose of diagnose. sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
Feb 12, 2012 | Exercise & Fitness
I lost the product key for my microsoft office 2003 and somehow it's no longer on my computer?
reinstall it ounce done it will ask you to activate software click on phone click witch country and it will give you a new key to tell microsoft then they will give you a new key to activate it if they demand the old key just tell them your dog ate it they must supply you with a new key so long as its an origanal microsoft disc
Oct 29, 2010 | Microsoft Office 2003 Student and Teacher...
Stuck in safe mode
Error Code: Replace Safety Key (SAFE)
Meaning: Safety key is not recognize
Diagnostic: Replace safety key
If problem persist replace upper display board
you should also try cleaning the area where you insert the key magnetic
Sep 11, 2010 | Landice L 7 Club Cardio Trainer Treadmill
3 yr old Smooth Fitness 7.1HR Pro won't Unfold
Did you unlock the lift control? You have to rotate the knob that is just above the pwer switch to let the unit lift or lower.
Feb 23, 2010 | Smoothfitness Smooth Fitness 7.6 HR Power...
I have a pro form performance j4 treadmill. i
It is just plastic. You can wedge a piece into the slot
Dec 22, 2009 | Exercise & Fitness
Proform Crosswalk 500 Treadmill Logo
360 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
