Question about RCA Televison & Video
Picture a little too tall
Vertical height a little too large-can't see all of titles across bottom of screen
  • 2 more comments
  • clovie71 Jul 15, 2009
    how do you adjust vertical height
    where is adjustment for verticak height
    • please advise where vert ht adjustment is
    • rcvr # is 27252gy--1999
    rcvr is 27252gy 1999yr
    where is adjustment for vertical ht
    President:
  • 1,462 Answers
You should tune the variable resistor corresponing to the vertical adjustment preent inside the box, if you are not familiar with opening the TV box or if you have not opened before just leave this to service man, its just a work to find the resistor for your TV model and tune it...
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMA
Posted on Jul 15, 2009
  • 3,230 Answers
If the screen is too wide from left to right the problem may be due to a fault in the width circuits. If the picture is too large from top to bottom the problem is with the vertical height circuits.
Good Luck!!
Thanks
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
1 vertical line across the screen maybe 1" tall. It appears to have the entire picture in that short little space.
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
Jul 16, 2010 | Toshiba 36A50 36" TV
An area across the top of the screen (approx 1/5th of screen height) is darker than the rest of the screen. I have a picture I can share if it would diagnose the problem.
Please share the picture.
Seems you have a vertical scan problems, which is usually caused by bad capacitors in the vertical output section.
If futher assistance is needed please leave comment
Delhielectronics@live.com
Sep 29, 2009 | Televison & Video
Model 32 sf36a picture size
most likley they are in the tech menue
you would need the service manul to access the proper proceedure the cause may be caps going bad in the vertical circuit
Aug 29, 2009 | Televison & Video
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
TALL PICTURE
On most TV units, there would be two (2) adjustments that affects your concern:
  • vertical Linearity (VLin); and
  • Vertical Height (VHt)
However, newer designs no longer have these adjustments since they are automatically done by the circuitry. If for some reason height is incorrect in such a system, then chances are that there is a leaky/defective capacitor in the vertical section.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 24, 2008 | Televison & Video
Missing bottom 1/4" of screen
It is possible that you have zoomed in your picture inadvertantly. Try going to picture settings and making sure that you are zoomed out all the way.
Hope that helps!
Dec 30, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
Picture is slightly rotated clockwise
HHHmmm Thats a weird one?? Have you moved or transported the set lately?? As it always been like this or did the problem just spring up?. Im thinking it was assembled with the yolks or the picture tube mount not level so when you lost a little bit of vertical height it shows up alot more then if the scan was correct. If it just happens after a move of some sort then the crt mount might have bent to one side a bit to cause all three tubes to move at once, cause if it wasent all three tubes you would have differant colors over the screen outlining every straight edge. Theres a little control on the sweep pcb called vert ht. Try if your brave to adjust the pic out alittle to pull the pic and make it larger BUT I will warn you if your not a tech and know electronics you could get a bad shock from the inside of this set as the set has to be on to make this adj. Also you could slip a little and thats all it will take to cause more damage then an alighnment so maybe you should inquire what a service charge will cost ya and make sure the repair person trys to adjust the vertical height before selling you a repair job as alot of techs will say its not normal for a set to lose vertical Height without a part going bad but thats not true as capacitors will sometims change value a little and throw off the height. Good Luck
Jun 02, 2006 | Philips 55PP9363 55" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
