Question about Locks & Locksmithing
No luck cutting a duplicate key on recommended blanks WR6 and KW1. Will go in the lock but not turn.
    Top Expert:
  • 9,098 Answers
Good Lock & Key - 11 Photos - Keys & Locksmiths ... - Yelp
www.yelp.com > Home Services > Keys & Locksmiths
Yelp
Rating: 4.5 - ‎137 reviews
He arrived within 20 minutes and made a duplicate key in his van within half an hour ...The key cutting machine in his van needs to be manually adjusted, so it is not as precise. ... I will definitely recommend Good Lock & Key to all my friends. ..... 24 Hour - Day & Evening Safes For The Home Keyless Locks Medeco High ...Missing: electronic ‎blanks ‎wr6
Lockworks Unlimited - Keys & Locksmiths - 2671 El Camino ...
Yelp
Rating: 4.5 - ‎97 reviews
I figured it would take 5 hours to replace the lock on the driver side door. ..... Bought aduplicate car key, had it cut, and programmed. ... I tried the key but no luck, the ignition was being peticular which may have had to do with the over torque which got me in this mess. .... 22 other reviews that are not currently recommended ...Missing: keyless ‎wr6
A-Abbot Locksmith Inc. - 14 Photos - Keys & Locksmiths ...
Yelp
Posted on Jan 22, 2016
    Sergeant:
  • 227 Answers
BARBARA, IS THIS FOR AN AUTOMOBILE IF SO GO TO THE DEALER
Posted on Jan 21, 2016
SOURCE:
My 99 jetta wr6 lost power but did not have a miss while at idel and once I cut it off it has not restarted . help please
Try your ignition switch on back of were key goes in on housing two very small flat screws with red dots unscrew and pull white base out it looks like a key put large screw driver in see if it will start
Mar 29, 2015 | 1999 Volkswagen Jetta
How can I find a duplicate key that has broken in half?It has a number on one side CH751 and looks similar to a Master Lock key.
The fastest and easiest method to get this resolved is to use a locksmith. If you contact the manufacturer, they might not respond in a reasonable time or at all. Call around and see what a locksmith charges and what they recommend. If you have the broken key they might be able to cut a new one for you from the broken pieces. They may also be able to come out and pick it and then change the lock for you.
Jun 22, 2014 | Sears Craftsman LiftMaster Chamberlain...
2000 Toyota. Key wont turn in trunk or door locks, but will start the ignition. Help!
I would try a spare key, or get a new key cut at the dealer from the vin code. Cutting a new key from the one you have may duplicate a problem with one of the cuts.
Dec 11, 2012 | Cars & Trucks
No juice no entry keys lost is there another way to get into a micromark electronic safe?
If you lose you keys, you will need to order duplicate keys from the manufacturer. They will need the serial number and model number of your safe and proof of purchase. After establishing the authenticity of the buyer, they will supply fresh keys at a nominal charge. The duplicate keys are specially ordered from the factory and takes 2-4 weeks for delivery.
However, for security reasons, if you lose your keys, we recommend to change the lock of the safe instead of supplying duplicate keys.
Feb 28, 2011 | Safe International Digital Electronic Safe...
I HAVE LOST MY HONDA ACTIVA KEY.CAN I GET DUPLICATE KEY FROM DEALER
Most dealers do not keep the original key number, it is sometimes written amongst the handbook and other paperwork you receive, if you do not have any luck with your dealer and cannot find the key number, try removing the actual ignition and taking it to a master locksmith, if you have a helmet/seat lock and it is the same as your main key than it may be easier to remove those locks, a master locksmith can cut the original key for your barrel/ignition.
Feb 18, 2011 | 2005 Honda Activa
The key will not unlock the door and it will not turn on the car
Chances are your key has worn out or you had a duplicate made and it was not properly cut. Take the car to the dealer or a locksmith and have them cut you a code cut key from the vin number on your car. The key will have to be programmed because of the transponder in it.Will cost you about $150.00 also spray your locks with WD40. Good luck
Jan 25, 2011 | 2008 Dodge Charger
Keys of honda activa lost can i get new or duplicate keys from honda activa dealers or i have to change the locks
Honda avtiva scooter purchased on 10.8.2007 against bill no.1469 for rs.37820 invoice no. 07IN02280 KEY no.8510 by my office colleaque mr mukesh kumar. The keys of the said scooter have been misplaced.HOW HE CAN GET THE DUPLICATE KEYS AND ON WHICH COST.Please inform urgently on my email or contact to mr mukesh on his mobile no 9463962353 as soon as possible.
RAJESHWAR
Jan 06, 2011 | Honda Fusion Motorcycles
I need extra keys for my Kwikset handleset. Had new keys cut at 2 different stores and none of them work. The keys fit in the lock, but won't turn either way. Original key turns very smoothly.
The problem you are having has nothing to do with your lock. Modern key cutting machines are so automated that they do a very poor job in key duplication. I suggest that you find an old hardware store that has an older key machine. Or possibly, it might be cheaper to simply replace the lock set. A new Kwikset keyed entry sells for about $40.00 for a lever handle. Remember to have extra keys cut at the store when you purchase the lock...so you can check the duplicates in the store. I do this at Home Depot regularly. They have a new machine, but with the lock right there, they can manage to cut some duplicates after a few bad ones.
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 24, 2009 | Locks & Locksmithing
1995 Hyundai Scoupe Spare Ignition Key
Any locksmith should have this blank and be able to cut it, the blank you are looking for is an Ilco X196
Apr 02, 2009 | 1995 Hyundai Scoupe
Locks & Locksmithing Logo
325 people viewed this question
Top Locks & Locksmithing Experts
john h
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
