Question about ASUS A7S333 Motherboard
Sound card Awhile ago I was cleaning out my computer for viruses and the such and trying to be a do-it-your-selfer when I must of deleted my sound card or something. How can I get it back? Limewire is useless without sound! I have little to no experince with this motherboard and probualy couldn't tell you much about it. Any ideas or solutions? your help would be great;y appreciated. Charles Sheefel
  • 1,601 Answers
Re: sound card
You probably uninstalled your sound card driver.
Here is how to check.
Posted on Nov 17, 2007
0 characters
3 Points
My memory card is full so I can't take more pictures. I want to delete the old ones which are saved somewhere in the disk but it only shows the old pics in the camera, only when i put the memory card...
If your memeory card is a SD card then -
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.You can then delete the phots using your computer OR format the memory card using the camera.
Jul 15, 2011 | Motherboards
I got a couple of virus infected my PC a week ago (Essential Cleaner & MS Removal Tool). I had to download instructions on how to remove such virus on the internet. I managed to remove the first virus...
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
SoundMax Integrated Digital Audio Driver v hope one of these helps
May 24, 2011 | Motherboards
I deleted my media can i turn it back??
Free File Recovery is a small and easy to use application that will help you to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from
digital cameraclip_image001.gifmemory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses! hope this helps
May 17, 2011 | Motherboards
I have an ASUS M2N-MX SE Motherboard and I have a Creative Sound Blaster Live 5.1 digital internal sound card (SB0220) I wish to install in the PCI slot on the mainboard. Windows XP recognises the card and...
Try to reattach your sound card. It will solve the problem. If it doesn't work you can format your computer or clean the viruses on your computer. If problem still occurs change the sound card.
May 15, 2011 | Motherboards
I received this isus notebook for Christmas. It had avira free antivirus on it ad was working fine. Two days ago I tried to use it and when it's in normal mode it will not load anything at all. I received...
Delete the anti-virus software.
Download FREE anti-virus software from Microsoft:
and install it. Allow it to do a "full" scan of your computer -- a computer-virus may be preventing the use of System Restore and Windows Update.
Feb 26, 2011 | Motherboards
What is urlseek20 and why its always appering everytime i try to go in facebook or google ?
You've got a bug...Malware. (Malicious software). Run malwarebytes, anti-malware and SUPERAntispyware in safe mode , what if found you delete manually then clean the pc with ccleaner and mvregclean. Use comodo pro firewall (free) and anti virus can be
avast,avira avg8 whatever its free. Don't attempt to update your virus scan before cleaning this but. AVG is good free virus scan.
Feb 07, 2011 | Motherboards
My cumpter sound can't play anymore
If you are using XP go to control panel and left click on sounds and devices icon.Check that mute is not selected and also check that realtek id default sound device.You could also try uninstalling sound card drivers and re-installing them in the Device Manager section. If you have onboard sound you may need to use a seperate pci soundcard which should come with drivers on cd but make sure you disable the onboard card first. Hope this helps.
Jan 11, 2010 | Medion (MT8381) (40004683) Motherboard
Cant reinstall the sound card driver of ecs elitegroup w341ui
The reformatting of the hard drive may not remove all elements of a virus, depends on the type. It may be able to hide in any case.
The best way to get rid of viruses on computers is to keep updated software which will scan all the time for viruses. If this is a Windows computer, going to safe mode and running the anti virus software will get rid of viruses. Another thing to remember is that the virus can get on to the computer hard drive again if you have any disks, cdroms or DVDs which were made when the virus was on it. Almost all viruses will copy itself to any media during infection. It is very important to have up to date software, whether or not you have to pay for it, and many are free.
Not a good idea to put your email on a site like this (any site for that matter).
I am not sure what you mother board is, but if it is "ALiveNF7G-HD720P M/board" with a Nvidia 7050 sound card.
Information you need when you go to the website:
The OS you are installing.
The Motherboard name and model number.
The exact name of the sound card and model number.
Here is a link, since you have not mentioned what your OS is, you can download what you need or email them, you may even be able to call.
Hope it all works out for you.
Sep 04, 2009 | Asrock ALiveNF7G-HD720P M/board, nVidia...
No sound
remove & reinstall your sound driver form the your motherbord cd
Jan 09, 2009 | ASUS K8V-MX Motherboard
Ga k8n ultra sli keeps locking my computer up
Maybe the problem is not in the hardware, maybe your system is infected by the spyware virus. Try to download pctools spyware and pctools registry mechanic it's good anti spyware and registry checker. Clean first the spyware and run the registry mechanic to fixed the damage registry that cause of hanging of your computer.
Apr 15, 2008 | R.A.M. Computers Gigabyte GA-K8N Ultra-SLI...
ASUS A7S333 Motherboard Logo
Top ASUS Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
