Question about Hampton Bay 04345 Cruiser Ceiling Fan
When I try to reverse the direction of the ceiling fan it does not run at all. It runs fine when it is in the directio of blowing toward the ceiling. Also, I have another ceiling fan on which the pull chain for the light has broken off. How do I replace the chain?
  • 34 Answers
Push the reverse all the way down or left completly.
Posted on May 23, 2010
Fan only wobbles on high....recently 'bumped'
Check all your screws especially the set screw at top of fan that goes into rod. Blades could be warped from the water. Ball of fan not set in bracket correctly. When your buying a fan, look for blade pitch.13 degree or better is best. You shouldn't have to use the fan on high unless it's a low-end fan with a low blade pitch. It's costing you more money to run the fan on high. Sorry to get so preachy, I'm a fan dealer .
Jun 19, 2013 | Dryers
Which way does a ceiling fan need to run in winter
Usually most peopledont want drafts on them in winter so making the fan turn with the edge thats turned down then that is the leading edge
IE say you look at the blade from the bottom
next note the blades are tilted you have to determine which way your blades are mounted. The fans may all be the same or some odd ones may be out there.
say looking up at a blade thTAs 12:00 from you
if the edge thats closer to the floor is on the left the fan turns left from 12:00 or Counter-clock wise to make the air blow toward the ceiling away from you. Reverse for cooling so the air blows on you.
This makes the air move upward.
If your ckoser edge is on the opposite side the fan turns opposite..
the edge thats turned down toward you is the direction of travel for winter
In small rooms with larger fan the air may make such a quick change that it feels like it blows on you in either direction.
Jan 15, 2012 | Hunter (25417) Ceiling Fan
I just installed a new hampton bay ultura 68" ceiling fan and the unit is only controlled by a remote control. The reverse function does not work and the fan only runs in one direction which happens to be...
After researching the complaints on this product I found that the reverse mode can be intermittent, the high speed can be slow at best and the returns of this product back to the store are staggering. Get a new but different model.
Jun 21, 2010 | Heating & Cooling
Ceiling fan won't blow any air
if its turning its either sucking or blowing air. There is a switch or a pull cord to reverse it. prove it to yourself with something light like a feather or piece of paper or balloon.
Aug 16, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Reverse
Do you want to sell your Covington Ceiling fans? I may be interested in purchasing them. If you live in Atlanta, I could remove the old ceiling fans and install your new ones if you need.
email me at:
myatlhomes@comcast.net
Aug 02, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Reverse ceiling fan
are you sure theres not a switch on the fan body ,, up/down= summer / winter...There should be
Jul 04, 2009 | Craftmade International (LC52EB) Ceiling...
Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Apr 28, 2009 | Emerson CF2600PW Raphael Pewter Ceiling...
I have found the right solution to the fan not working in the right direction. the problem is that is a pcs of trash, i ripped mine off the ceiling and tossed it out the window and guess what it, it flew...
Did you hit the reverse direction switch located on the upper fan body. Upward direction is for winter as it blows up toward the ceiling pushing rising heat out towards walls and down to floor. Downward direction sucks heat off ceiling (summer months) and pushes cooler air that is on the ground toward the ceiling, thus giving a cooler airflow. You do know that there is a little black switch up there, right?
Feb 28, 2009 | Hampton Bay 24002 Ceiling Fan
Had a ceiling fan with dual purpose, one to blow air upwards durng the cooler months and one downwards during warmer mos. unable to set the fan to blow air downwards.
Explain set it. Generally there is a switch on the fan to reverse, are you attempting reversing by that switch or a wired in wall switch? If it runs in one direction it will run in the other. Something in the control is broken or not wired correctly.
Sep 16, 2008 | Heating & Cooling
I instant a Hampton bay fan with a remote, the fan will not go in the forward cycle only reverse
the connection to the motor has been reversed which makes the fan to run in reverse direction interchange the terminal then it will run in the forward direction
Jul 22, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 04345 Cruiser Ceiling Fan Logo
165 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
