Question about JRC Jma-2343 4kw Crt Radar
Need diagram for wiring jrc radar 1500
I need to know how to wire it up. there are several wires instead of just red and black
2 Suggested Answers
  • 35 Answers
SOURCE: JRC Radar Scanner when rotating
There is a seal on the antenna scanner shaft, just below the seal there are two bearings, thou the antenna are enclossed moisture still get inside and get to these bearings. Try and get a small amount of wd40 on the bearings, if not, you will soon begin to see false echoes on the screen because the motor on the scanner or antenna will begin to work harder causing a drag causing these echoes. Good luck.
Posted on Jan 30, 2011
What wire to solder on the ciggy plug?
Red is your positive black is ground yellow constant power green is a wire that does not need to b used nor the yellow unless u want constant power to the unit positive red wire goes to the front of your ciggy adapter black can go on edit hie side of the two grounds that hold your ciggy adapter inside the socket hope this sheds some light on it
Mar 03, 2014 | Passport 8500 X50 Radar Detector
I lost my cord and would like to make a basic power cord can u send me a diagram that shows the color code on the end that looks like phone wire i have material but i dont know where which wire goes...
on a 4 wired RJ11 or Rj12 Phone plug, it's the middle 2 wires. green and red are your positive and neg. Do a quick touch test to confirm which is pos and neg. only works one way. after confirmed. solder the wires and wrap insulation tape around each and then a couple times over both for strength. the phone wire is prone to breakage.
Apr 23, 2011 | Vector 995 Radar Detector
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
Wire connection from chartplotter to radar dome
yes? what about it? it is difficult to guess what you wanjt from this description with no other leads.
Generic problem for all JRC GPS Devices Wire connection from chartplotter to radar dome
Oct 09, 2009 | JRC GPS
Where do all the wiring go to on the garmin 400c
The rest of the wires are for interfacing (letting the unit 'talk') with other devices such as radar or GPS. These wires/colors are pretty standard and defined by NEMA (National Electrical Manufacturers Association). You need wiring diagrams for the devices to hook them up. For fun, see where 'nema' takes you with Google.
Jun 18, 2009 | Garmin Fishfinder 400c With Dual Beam...
I need schematics off jrc radar 1500
Ask at http://manualfox.com/schematic.htm
If anybody can find it, this is the right place to ask.
Apr 27, 2009 | JRC 1500 MKII Radar
Trying to hook up cable to a raytheon r10 radar scanner.Needs wiring diagram to show where each wire goes.
Large Blk and Large Wht goes to 2a
Large Red goes to 1a
Grn goes to 1b
Blu goes to Bz
Coax goes to Vd
Wht (shielded) goes to Gs
yel goes to 33
Red Shielded goes to Bp
Brn (small) goes to pl
black shielded goes to tI
Large brown not used tape end fold back and secure to harness.
Apr 19, 2009 | GPS
Draw down is to high
found my fault not i the power cable in, but the interconnect to radar dome..approx 50mm from radar screen a break in the wire, found it just by wiggling the cable.. the set wont power up if the interconnect not connected or is faulty
Apr 07, 2009 | JRC 1000 MKII Radar GPS Receiver
Jrc 1000
Hi , I have a JRC 1000 with manual if it can helps ( in English and french but i ma in france. You can also use the installation manual of JRC 1500 available on internet under pdf format , very similar ( same screen and operating interface )
pcg1@orange.fr
Jun 13, 2008 | GPS
JRC Jma-2343 4kw Crt Radar Logo
Top JRC Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a JRC Boating Expert? Answer questions, earn points and help others
