Question about Carrier 52FE312-3 Air Conditioner
Carrier window unit model# 52FEA312321EC, 1PH 230/208V
New unit but without electrical cord. What cord will I need and where and what do I connect this cord to. Thanks for your help, Larry
    New Friend:
Need to replace Model # 52FEA312321EC by Carrier where do I find one?
Posted on May 22, 2016
  • 80 Answers
YOU WILL NEED TO CHECK THE PLATE ON THE EQUIPMENT TO SEE WHAT VOLTAGE IT IS MOST LIKELY 220 VAC THEN YOU WILL NEED TO SEE WHAT YOUR PLUG IN YOUR WALL LOOKS LIKE - . - OR [ . - BRING THIS INFO TO YOUR LOCAL HOME DEPOT AND THEY WILL GIVE YOU A CORD
Posted on Nov 29, 2007
I have old carrier 50zp060511s Air Conditioners that having voltage details like 3ph 220V 60hz UL Standard But now i have voltage of 400V 3ph & 230V 1ph.. is there any solution for this issue..
If you are reading 400 volts coming into the unit, call electric company. You should only have 220-240 from your power lines. Anything over that will burn out unit. P.S. In my opinion Carrier Units are the best and longest lasting when properly maintained.
May 08, 2016 | Carrier Heating & Cooling
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Jul 28, 2011 | Lexmark X6570 InkJet Printer
I replaced the power cord on a carrier ac window unit 24000 btu model yc-d , now the compressor will not shut off regardless the thermostat setting
You have probably one wire in the wrong place on the back of the switch. There should be a wiring diagram near the electrical compartment on the window unit. It will show you where the wire needs to be. You are probably just a terminal off.
May 01, 2011 | Heating & Cooling
Error1102 Invalid Cartridge, but it has been working and now I get this message without any change in cartridge.
  1. Remove the print cartridges, and close the cartridge carrier lids.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
  5. Reinsert the print cartridges.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
  5. Reinsert the black (or photo) print cartridge.
  6. If the error:
    • Reappears, replace the black (or photo) print cartridge with a new one.
    • Does not reappear, reinsert the color print cartridge.
  7. If the error reappears, replace the color print cartridge with a new one
Please rate & vote,If you like solution...
Thanks
Mar 14, 2011 | Lexmark P4350 All-In-One InkJet Printer
We have a Intertherm Furnace Model # MGHA-056ABCFC-01 Serial # MGH9205-01793 115va 60hz 1ph 5.9amps 1/8hp rpm 1050 We need to find a blower motor and a blower wheel for our furnace. Can you help...
Phone book, refrigeration distributors, call and give unit make model # serial # 1ph 1050rpm 1/8hp and frame type of motor. Usually a belly band. Though any good parts house can get all needed info off of make model serial. You might need to call a few since many will not sell to you if you are not licensed.
Feb 26, 2011 | Heating & Cooling
My mom has a RHEEM 40gal electric hot water heater...model 87H 40D 1PH, Serial # r0288003951. It is the table top version. She said that the hot water is no longer working and before I request a service...
first check that the thermostat is working im afraid if its not a fualt there the chances are its the element in theboiler that means a new boiler in most cases
Nov 13, 2009 | Water Rheem MR40245 Marathon Electric ...
Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Sep 20, 2008 | Garden
Carrier 52FE312-3 Air Conditioner Logo
1,004 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
