''F 02'' error message and not draining water
Giving me an ''F02'' error message and won't drain the water out and won't drain the washing liquids from the drawer.
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Jul 15, 2009
Won't finish the wash cycle and flashes the code F 02
This code means that the machine is not evacuating its water.
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jun 09, 2011 | Kenmore Washing Machines
Whirlpool washer ghw9150pw0, error message f02. I have removed, cleaned and checked all drain lines and checked backflow ball. everything is good. May I assume the pump is bad.
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
The f02 error code is a long drain error meaning the following and here is what needs to be checked before replacing the pump
Long Drain
Jun 06, 2011 | Washing Machines
Stops in cycle and says f 02
F02 error is related to drain pump block.If the drain pump gets blocked or the drain hose is blocked the error comes up,this is indication of cleaning the drain pump and drain hose.If the drain pump and drain hose checked ok then its faulty drain pump,its not draining the water so the error f-02 is showing up. error F-02 is a slow drain problem. Remove the wide tapering pipe from the drum to the pump. Inside there is a non return ball valve. Clean this and see if that helps. Take the front bottom panel off and open the drain trap,and see if there is any thing got stuck up,like coins,nails,socks or any small cloth etc etc.--------------While removing the drain pump and drain hose for cleaning,please keep thick towel with you.As you disconnect the drain pump from its connection,lot of water will flow towards you,if your machine is filled with water.So keeping this towel with you will help to control this water flow towards you.This should help.Thanks.Helpmech.
Jan 19, 2011 | Washing Machines
My whirlpool front loading washing machine keeps saying F02 and not draining out the water. why? and what does F02 mean?
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Whirlpool Washing Machines
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite error message F 02
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
Is giving me F 02 error and will not drain and spin
F02 is the code for a long drain.if the drain time exceeds 8 minutes,the water valves are turned off and "f/02" is flashed.press pause/cancel twice to clear the display.check the drain hose and make sure it is not plugged or kinked.check the electrical connections at the pump and make sure the pump is running.check the drain pump filter for foreign objects.if the above does not correct the problem,replace the pump.
Jan 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Will not drain. Getting error code F02
yes exactly.you are right.its the pump problem. F/02 error code:-- Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
try this :-- Press PAUSE/CANCEL twice to clear the display.
:Check the drain hose and make sure it is not plugged or kinked.
: Check the electrical connections at the pump and make sure the pump is running.
: Check the drain pump filter for foreign objects.
: If the above does not correct the problem, replace the pump.
you can get required parts from www.repairclinic.com
Nov 27, 2009 | Kenmore Washing Machines
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
Oct 24, 2009 | Kenmore Elite HE5t Washer
F02 error message. What does this mean and what do I need to do?
Her is what f02 means for your washer.
Long Drain
Her is what to look for.
Good Luck
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
