Samsung Digimax L830 Digital Camera
Problem for Samsung Digimax L830 Digital Camera
My samsung L830 camera has jammed with the lens open and
By joolesbromle on Jul 15, 2009
my samsung L830 has jammed with the lens open and will not turn off or on.
Solution #1
posted on Aug 01, 2009
Not Rated)
lunaticsanon
Rank: Master
Rating: 83%, 17 votes
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730.
Was this helpful?
Yes
No
Solution #2
posted on Jul 31, 2009
Not Rated)
here33
Rank: Apprentice
Rating: 0%, 0 votes
Just had this happen to my L100. First, take out the battery and wait a couple hours for everything to cool down and discharge. Then place the battery back in. Then plug the USB cord into the camera and PC. Then turn the camera on and it should be okay. Just worked for mine.
Comments:
Jul 31, 2009
- P.S. - I also let the camera stay on for a couple hours to try to drain the battery too. Don't know if that will make a difference....
Was this helpful?
Yes
No
Popular Solutions for Samsung Digimax L830 Digital
Questions and Unsolved Problems for Samsung Digimax L830 Digital
Do you recommend Samsung Digimax L830 Digital Camera?
Answer
Answer
simply will not power on and overheats when charging
Answer
The LCD screen is completely white with a little black line through it. Can't see anything.
Answer
mode dial do not work in digital camera samsumg L830
Answer
when attampting to turn camera on there is no response accept a loud bleeping. Battery is fully... (More)
Answer
im having dificulty watchinng my videos ive took on my SAMSUNG L830 camera all it does is play music... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung Digimax L830 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 382
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
