DVD Players
Problem for DVD Players
Generic problem for all DVD Players
How do you hook up the dvd player to the...
By grandmas8 on Jul 15, 2009
how do you hook up the dvd player to the tv with a vcr hooked up to the tv
Solution #1
posted on Sep 10, 2009
Not Rated)
ymcsmaxtitan
Rank: Apprentice
Rating: 0%, 0 votes
DVD player to TV.
Was this helpful?
Yes
No
Solution #2
posted on Jul 15, 2009
Not Rated)
rkavi312
Rank: Wiz
Rating: 79%, 53 votes
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Was this helpful?
    Yes
    No
    Popular Solutions for DVD Players
    Questions and Unsolved Problems for DVD Players
    Answer
    what sort of scart lead for product dvp3360
    Answer
    Which is the Best and Lower Price DVD player
    Answer
    ddoes a 5.1 home theatre system work with this player?
    Answer
    Need input cable for video to the Initial dvd player. Where can I find one?
    Describe your problem:
    Select a Category:
    Ask our Experts
    Solve Your Problem Now!
    Chat Live with an Expert
    Chat Now
    Top DVD Players Experts
    Top TV Repair
    (859) 609-2887
    SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
    (21591) 042-9690
    Chat Now
    Insert Link
    Insert Image
    Insert You-Tube clip
    Insert List
    Insert List
    Spell Check
    What is this?
    Select
