Question about HP Compaq 8510p Notebook
How much I try to start the wireless it just enables bluetooth...
When I start Windows mobility center I can see that wireless is disabled and I cannot snable it, the button is greyed... Checked the drivers and all seems ok... checked BIOS and all looks fine... Any solutions?
  • petri369 Jul 28, 2009
    Didn't help... uninstalled WiFi-device twice and problem still persists. Searched for newer drivers, but seems like I got the latest drivers for this device.
I have an HP Pavilion dv6-6135 and when I googled my wi-fi problem, there were a lot of HP Pavilions in the same boat. One person has a video on how he by-passed the motherboard with wireless adapter to fix it. Obviously it is an HP pro blem that they just keep let happening on each model.
Posted on Jul 09, 2012
    President:
  • 1,383 Answers
Go to device manager press windows key + pause break key then you can see system property then click on hardware then devicemanager then uninstall your wifi drivers then install again then check.
Please rate my solution thanks.
Posted on Jul 15, 2009
I can't connect to WiFi. Any advice?
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
Jun 04, 2014 | Computers & Internet
How do i turn on my hp windows vista bluetooth raido transmitter
To turn your bluetooth on do the following process.
1.Click Start , type wireless into the search field, and then select HP Wireless Assistant from the list.
2. By default, the Status column shows that both of the wireless devices are either on (enabled) or off (disabled). Also, by default, the Action column does not display.
If you want to control one of the wireless devices individually, without affecting the other devices, clickProperties , and then select the Independent controls for installed wireless devices option.
If you have removed the HP Wireless Assistant, it can be reinstalled using the Recovery Manager service.
  1. Click Start , type recovery into the search field, and then select Recovery Manger from the list to open HP Recovery Manager.
  2. Select Advanced options .
  3. Select Software program re-installation and then click Next .
  4. When prompted, click Next .
  5. Select HP Wireless Assistant and then click Next .
Follow the on-screen instructions to complete the installation of the HP Wireless Assistant.
You can verify the device is installed & enabled with Windows Mobility Center.
To turn Bluetooth devices on or off, do the following:
  1. Click Start , type mobility into the search field, and then select Windows Mobility Center from the list to open the Windows Mobility Center. Alternately, press the windows key and the letter x key at the same time.c01577398.gif
  2. Use the drop-down menu items in the Integrated Wireless Devices selection to turn the devices on or off.
    I think the above tips are helpful to you.
    Thank you for using fixya.
Oct 05, 2013 | Radio Communications
How do i switch on the wifi in my dell inspiron 6400? The Fn + F2 command is switching on the bluetooth only
You can turn on/off Bluetooth and Wireless using the Fnand F2 key.
To enable or disable wireless networking, press <Fn><F2>.
Turns on when a card with Bluetooth® wireless
technology is enabled.
NOTE: The card with Bluetooth wireless technology is an optional feature, so the ordered the card with your computer. For more information,
see the documentation that came with your card.
To turn off only the Bluetooth wireless technology
functionality, right-click the
area and click Disable Bluetooth Radio.
To quickly enable or disable all wireless devices, press
<Fn><F2>.
Please refer the page #69 to 74 for complete information on the Wireless and Blue-tooth
http://support.dell.com/support/edocs/systems/ins6400/en/om/MD402AO3.pdf
Jun 28, 2010 | Dell Inspiron 6400 Notebook
THE MIDDLE DISPLAY LIGHT AN "A" FLASHES WHEN i TRY TO START IT AND IT WONT TURN ON
Turns on when the numeric keypad is enabled.
Turns on when wireless devices are enabled.
Turns on when the uppercase letter function is enabled.
Turns on when Mini PCI functionality and Bluetooth® wireless technology are enabled. To enable or disable Mini PCI functionality and Bluetooth wireless technology, press <Fn><F2>.
NOTE: Bluetooth wireless technology is an optional feature on your computer, so the about31.jpg icon turns on only if you ordered Bluetooth wireless technology with your computer.
For more information, see the documentation that came with your Bluetooth wireless technology.
Turns on when the scroll lock function is enabled.
Here is the answer! memory problem! go to this site. http://www.laptop-junction.com/toast/content/dell-caps-lock-light-flashing-blinking
May 30, 2010 | Dell Latitude D610 Notebook
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
Dec 02, 2009 | MSI U100-001US Netbook
Bluetooth config
You can enable it by hitting your windows button on the bottom left of your keyboard and then hitting control panel. From there, go the the blue icon that says bluetooth.
Sep 21, 2009 | Computers & Internet
Reloaded Windows Vista
you can try the ff:
► double check the wireless if it's enable or disable. click start > start search > windows mobility center > turn the wireless network ON.
1) reinstall the wireless driver of the computer using the driver disc or using the recovery partition....
2) tried to set-up the home wireless conenction in "Home Set-up Wireless Network" and follow the instruction.
3) reseat wireless card if it's reseatable.
4) download the BIOS update using ethernet cable from the pc website support.
3) contact Internet Service Provider.
4) reinstall the windows to the factory condition.
Sep 19, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Help - pc doesnt detect my blue-tooth enabled cellphone!!!
Go to Windows update or update your software and driver from the items website..
Jun 01, 2008 | Billionton (GUBTCR41ABT) Wireless Adapter
How do I turn bluetooth on and connect a Mobile phone to a Acer Aspire 5710G
Windows Mobility Center includes Acer-specific settings like Bluetooth Add
Device (if applicable), sharing folders overview/sharing service on or off, and a
shortcut to the Acer user guide, drivers and utilities.
To launch Windows Mobility Center:
Start Windows Mobility Center from the Control panel
Start Windows Mobility Center from the Accessories program group in the
Start menu
You should be able to turn on blutooth from there.
Please let me know if this helps.
Mar 17, 2008 | Computers & Internet
HP Compaq 8510p Notebook Logo
234 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
