Question about Amcor AD400 Dehumidifier
How do I keep the humidistat set at a constant %? It keeps reverting back to 90+ %
I've misplaced the owner's manual on a DEN 500 P. What is a good basement setting for Summer in Central Ohio? Is a manual available on line?
I bought a cheap digital humidistat at Walmart to keep an eye on the humidity in my basement. I hung it on the wall not too near my dehumidifier. I have found that the settings on the dehumidifier are misleading, but I found a setting that keeps my humidity between 40% and 55% (at around 70 degrees), as measured by the humidistat.
Jun 04, 2012 | DeLonghi DE500P Dehumidifier
How do I reset the dehumifier "set humidity" back to 35. It's on 90 now.
To reset the electronics of the dehumidifier, turn the OB/OFF Switch to OFF and unplug the unit for 10 minutes. After the time has elapsed, plug the unit in and turn the ON/OFF Switch to ON. During that time out, the electronics should have reset and reverted back to the original factory settings. From there you can set them as you like.
I hope this helped you & thanks for choosing FixYa.
Aug 22, 2011 | Dayton 1DGX6 Dehumidifier
The coil keeps iceing up
is the filter and coil clean? In high humidity the unit mat run too long and freeze. Try turning the humidistat a little lower
Aug 21, 2010 | Oasis Dehumidifiers
My Goldstar Dehumidifier keeps cutting off even though its not full of water...any help?
A few things you could try are to make sure the float isn't covered in gunk and moving sticky-like, make sure air filters are clean and the compressor isn't overheating, and make sure the humidistat (probably a knob that says drier with arrows) isn't turning the machine off because it's reached the set level.
Nov 25, 2009 | Goldstar Dehumidifiers
DeLonghi DEN500P Dehumidifier Humidistat
I have the delonghi DEN500P and the unit runs but does not condense any moisture? The appropriate buttons have been set to bring the unit humidity setting well below humidity in room
Aug 03, 2009 | DeLonghi Dehumidifiers
LG Goldstar dehumidifier runs constantly
sounds like the rheostat (aka rotary swithch) is opened (fried). can get new one on www.appliancefactoryparts.com for 8.19 + s/h. need to know how to solder though. otherwise you will be looking at having to buy new unit for $120+
Jun 28, 2008 | LG DH30 GoldStar Dehumidifier
Delonghi Dehumidifier DE400P / DH400P says error Code E1
Hi.
It is simple and easy to fix. E1 code for sensor behind right side grill. Take right side grill out, unplug sensor from wire socker and plug back. It is solve problem sometimes. Unit MUST be unplugged from outlet.
If no help, you need new sensor .
Thank you.
Dimitry.
Nov 10, 2007 | Dehumidifiers
Humidistat
the humidistat is inside the machine behind the control panel. it has a mylar piece that expands and contracts according to room humidity. one side is connected to a super sensitive switch that is part of the fan/compressor circuit. you could just jump this out with a piece of wire but you'll have no control over the humidity. the unit will just keep on running.
Sep 06, 2007 | Kenmore 54501 Dehumidifier
A Question
You can test the humidistat fairly easily, using a volt-ohm meter. Just set the meter to RX1 scale and attach its leads to the humidistat's terminals. Rotate the humidistat's knob as far as it will turn in both directions. If the volt-ohm meter registers zero ohms through only part of the humidistat dial's range, the humidistat is working. If it registers zero through the entire range, it's broken and must be replaced. Dehumidifier Overflow Cutoff Switch Test- Using a volt-ohm meter, you can tell if the overflow switch works or not. Clip the leads to the terminals on the switch. Depress the bar or trip lever on the switch. If the meter's needle doesn't show continuity and no continuity as the switch is clicked back and forth, the switch is probably faulty and will need replacement.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Amcor AD400 Dehumidifier Logo
27 people viewed this question
Top Amcor Dehumidifiers Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you an Amcor Dehumidifier Expert? Answer questions, earn points and help others
