Question about Garden
Starts fine, stalls when clutch/brake released, in neutral or forward/reverse from side of mower:ryobi rt190kohler 19hpplate on mower:electroluxmodel # 9601600040pnc # 96016004serial # 041205d004214catalog # hdk19h42
  • 61 Answers
Ck spark advance module
Posted on Sep 06, 2009
Model YTH180 tractor. Why does it go fine in forward but reverse is slow?
Linkages to the transaxle may be wore or out of adjustment also check the brakes they could be binding while reversing.
Low ground speed: If the linkage is not synchronized to absolute neutral, or the shift lever is not properly fastened to the tapered control shaft, full forward / reverse travel may not be achieved. This may cause a false reading and be misdiagnosed as a low power condition. This also could be caused by the brake not releasing.
To determine absolute neutral, the hole in the tapered control shaft must face straight up and down, at this point make sure the OEM linkage is in neutral. To properly fasten the control lever to the shaft, torque the nut to 25-35 ft. lbs. (34 - 48.3 Nm) of torque with the shaft and the lever in neutral. When attaching the shifter arm to the shaft you must prevent any rotation during torquing. This can be done
by placing a long 5/16 bolt in the hole of the shaft. Hold the bolt until the tapers are locked and the nut torque is correct. To make sure that the brake is not binding, drive the unit up a slight grade.. Position the speed control lever into neutral. The unit should coast backwards. If the unit does not coast back slowly, the brake is not
released from the brake disk. Adjust the brake linkage to release the brake completely when the foot pedal is released.
Feb 16, 2016 | Husqvarna Garden
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
May 16, 2012 | Garden
Tried takinf the machine out of the shed and found that the machine starts and runs as normal, but the tractor will not drive forward, or back. Diff apears ok as one wheel is trned by hand the other...
Hi, if you can't push the mower there is a short lever on the right hand side of the diff that the brake pedal is attached to, make sure it is not seized forward. If you can push the mower, start the mower and with it in neutral, select top speed, fully release the clutch/brake pedal, push the pedal hard forward again then select any gear and release the pedal again. This resetsthe vari-speed pulley. If none of this works check that the rear drive belt idler pulley arm is free. Hope this helps, regards Phil.
Aug 19, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
HELPING A FRIEND WITH A CRFTSMN 18HP FRNT ENGINE LT2000 LAWN TRACTOR. THE ENGINE RUNS GREAT BUT WHEN HE RELEASES THE CLUTCH/BRAKE TO GO FORWARD OR REVERSE THE ENGINE DIES.
Put trans in neutral if trans is a gear drive and see if mower can be pushed, if it can you can push rule out stuck brake. If you have a hydrostatic trans you can put trans in bypass and push to see if brake is stuck. Remove drive belt at engine or at trans and try the cluch, if motor stays running there is a trans problem.
Mar 13, 2010 | Craftsman Garden
Craftsman 42 in 19.5 unable to control speed forward motion
is this perhaps a hydro trans? if so, try putting the shift lever in neutral, then let off the brake pedal, use the shift lever to go forward and to neutral to stop - same with reverse, don't even use the brake pedal except for emergency stops. if it's a manual shift, it's possible the belt is incorrect, and/or the belt guides are bent or the belt is improperly routed - the belt guides are important as they allow the belt to "blossom" off the engine pulley, reducing the "shock" load when engaged - hope this helps
Jul 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Garden Logo
251 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
