Question about Acer Aspire 5315 Notebook
O/S Vista I have the recovery disks and backup error
O/S Vista I have the recovery disks and backup disks and when I try to do a C/D restore I get this error 0XD000001E on disk #8 out of 9 plus I lost the Empowering technology password thats lets you Restore factory thank you
  • 91 Answers
The restore distk u have have curroupted...... Please try to order new recover disks so that u can install the OS with out any issues............ Further quries please do let me know.... Take care BYE
Posted on Jul 15, 2009
Why won't Windows Error Recovery tools work?
This means that the hard drive is corrupted such that the Windows Recovery tools can't solve the problem. You may have lost the MBR or the partition table.
The PASS means that there are no bad sectors. However, it doesn't check for bad files. If the problem is in the MBR, you will need a Windows OS install or upgrade disk for your OS (x32 or x64) or a recovery disk. Some members of a Windows Users group may have spare copies of the install disks. Alternatively, a third-party partiton management recovery disk may work. I hope you have a recent backup though since restoring from the backup may be needed.
If the problem is with the MBR, press F12 repeatedly on powering up the computer. Select the CD/DVD drive from the list (This is the one-time boot option. If you miss the timing, power down and retry.) With a Windows CD/DVD, follow the on-screen prompts to access the disk and choose Repair your computer. (This option is in smaller text below the Install now button.) Select the command prompt option. From here: type in "bootrec.exe /ScanOs" (without the quotes) and press enter. If any Windows installs are found, you are good to continue. The command, bootrec.exe /RebuildBcd , may be sufficient. If it isn't, use the bootrec.exe /FixMbr and bootrec.exe /FixBoot commands after rebuilding the BCD file. (Press enter between each set of commands.) Try starting the computer and create a new backup soon if it works. For other partition tools, follow their directions for MBR repairs.
If bootrec.exe /ScanOs doesn't find any Windows installations, try accessing other drive letters until you find your Windows OS. (For example, type C: or D: and press enter. Then type dir and enter.) If you have access to another computer, pull the drive and use a hard drive dock or USB to hard drive adapter to check the disk out elsewhere. I recently had a drive that reported having a RAW format with most tools. In my case, I was able to use a specific recovery tool, TestDisk for Windows, to salvage a few files that were newer than the last backup. Sometimes, this tool will be able to recover the partition table. (Use this tool with extreme care, it may render any original hidden backup partition unusable.) There are other disk recovery tools out there; some may work. You may want to run additional disk health tests while at this second machine.
If the system is faulty but the drive is otherwise healthy, restore using your last backup or the Dell Backup and Restore Utility. The Utility may be in that list of options after you press F8. (Note: the Dell Backup and Restore will return the system to the factory settings. Since the system started with XP and the above header indicates the Vista OS, there may not be a recovery partition available. Similarly, if you upgraded the hard drive, the recovery partition might not be usable.) Follow the directions from your manual/on-screen. If your backups are on CD/DVD or you have a recovery disk, use the F12 process to access the backup.
I will admit that with the recent drive I just fixed, the restore from the back up left a problem. This system was a Win8.1 drive and ended up with a MFT mirror issue. I solved this with the chkdsk c: /offlinescanandfix command on the next restart. (This is a switch option only available with newer Windows systems and the NTFS file system. The usual command would be chkdsk c: /f /r /x .)
I hope this helps.
(The Windows 8.1 system above had a hard drive replacement 2 years ago and was built in late 2008.)
Mar 30, 2015 | Microsoft Windows Vista Home Premium with...
Windows vista recovery cd I created won't install on new hard drive
Which software did you use to create the recovery disk? Is the recovery disk a CD or DVD?
Just to recover a vista system from recovery DVDs would require at least two DVDs. Your files would be in addition to this so I would be very surprised if you have only a single disk containing both the operating system and all of your files.
A simple recovery disk would only be useful for restoring lost operating system files to a hard disk that had corrupted or deleted files. It would let you restore to a new blank disk.
If the disk only contains a backup of your data then you would need to first install an operating system (Vista or Windows 7) and then install the backup software you used to create the disk and then you could recover your data from the disk.
Jan 05, 2013 | HP Computers & Internet
Error when recovery with vista
It is an effective solution for repair your damaged or deleted BKF files due to sudden system failure, virus attacks, media malfunction, backup interruption etc. Using this software, you can easily repair your BKF files. If you want to use the demo version of this software, then you can go on official site :- BKF File Recovery Tool
May 05, 2012 | Computers & Internet
ERROR 1002
This error can occur during a system recovery, and choosing the backup option to an external hard drive. The recovery might stop responding, and an Error 1002 message displays.To resolve the error, follow these steps:
  1. After the error message displays, turn off the computer.
  2. Disconnect the external hard disk drive.The backup is still useable.
  3. To continue the system recovery, restart the computer.
  4. Press F11 repeatedly at startup.
  5. Select Advanced Options , and then select System Recovery .
  6. When given the choice, choose to continue without a backup.
  7. After system recovery is complete, restore files from the external hard disk drive.
Jul 04, 2010 | Dell Dimension 8200 PC Desktop
Sony Vaio VGN N320E won't start - recycles to error window have a vista repair disk - doesn't seem to work - trying to save precious photos before ordering recovery disks from Sony Would like it to start...
You can backup the data and restore it to factory settings.
Please restart the Computer, press the F10 key at startup to access the Recovery Center.
Select Rescue Data option to backup the data to an external USB Hard Drive or thumb Drive or CD/DVD Disc..
Select Custom Rescue Data option to backup the individual data.
Once the data is backed up, select Restore C Drive option to restore the Computer back to the factory settings.
Apr 18, 2010 | Sony Computers & Internet
System is running extremely slow, when I tried to do a factory restore I get an error code 0xf00000005. I ran hardware diagnostics on the hard drive memory cpu and mobo, tests run extremely slow. I tried...
After using Darik's boot and nuke (DBAN) your hard drive will be wiped clean with little chance of recovery. This also depends on how many passes you used for the disk wipe. More passes = less chance of recovery.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process.
Jan 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
Error 0XC000000C and 0XD000001E and 0XA0000001 how would I fix these errors its on a Aspire 5315-2153 Notebook did have Window Vista as OS I tryed the backup disc I made 1-9 error OXC000000C on disc 7 I...
My 0xc000000c "Restore Failed" prompt seemed to be the result of disk surface damage on the restore disk. After burning the restore disk to a new disk, the restore proceeded normally. Try making a copy of the original restore disk to a known good blank disk.
Jul 20, 2009 | Computers & Internet
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
2 Press Alt + F10 to open the Acer eRecovery Management utility.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Follow the instructions on screen to complete the process.
Restore from backup
click Next.
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
Backup for Sony vaio
If you got the recovery disk along with the Vaio laptop, good enough.Insert the disk and reboot, follow instruction displayed on the screen to restore.
If you dont have a disk, can try this :--
Reboot and press F11 to try and enter the system recovery mode, if you can then you're good, simply follow the prompts to perform a system recovery.
Let me know the status please.
Thanks
Mar 30, 2009 | Sony VAIO PCV-RS710GX PC Desktop
Backup and recovery
Delete the System Recovery Files folder located at C:\System Recovery Files then try to run the backup.1.exe program again. I also found the you have to have the Backup.2.fbw file burned to a DVD before it will restore the files.
Rayna
Jun 10, 2008 | Microsoft MediaRecover File Recovery...
Acer Aspire 5315 Notebook Logo
321 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
