Seems to have blowback.... Started after had an oil change that was overfilled but since drained to below desirable level so certainly not overfilled now. Have replaced the O ring at the top of the dipstick
Oil cap leaking - Harley Davidson Forums
www.hdforums.com/forum/sportster.../550364-oil-cap-leaking.html
Aug 13, 2010 - There is always a big amout of oil at the bottom of the bike (probably all from oil cap) and it's drippin' all the time especially if bike is hot.
2007 sportster 883 leaking oil
May 31, 2009
Sportster Oil Leak
Oct 3, 2006
More results from www.hdforums.com
Oil leak at filler cap - Stromtrooper Forum : Suzuki V-Strom ...
www.stromtrooper.com/v-strom-service.../78495-oil-leak-filler-cap.html
Aug 24, 2012 - but more so it seems to me that a new bike shouldn't be leaking oil at all. ... Do I just need to have the dealer replace the seal on the filler cap?
Harley Davidson Motorcycles : About Slobbering Oil ...
? 2:20
https://www.youtube.com/watch?v=lB2DpvxKTGw
Dec 1, 2008 - Uploaded by expertvillage
For your help, there are few Car Engine oil related solved problem
listed below. You can go through it.
High Oil Level on Dipstick
http://whatisbyme.blogspot.in/2012/06/high-oil-level-on-dipstick.html
Oil light came on and the car died?
http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html
How to replace Oil filler cap or breather cap?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html
Oil pouring out from left front of engine?
http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html
Common Causes of Car Oil Leaks?
http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
Troubleshoot Car Oil leak?
http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
2004 Dodge Stratus: Windage Tray Problem
http://howtobyme.blogspot.in/2012/07/2004-dodge-stratus-windage-tray-problem.html
Toyota Highlander Sport Oil change details?
http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html
Low
oil pressure light on Dodge Magnum?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
Kia Sportage leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
Car Turns OFF
due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
Toyota Corolla leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
Overfilling oil in engine?
http://whatisbyme.blogspot.in/2012/06/overfilling-oil-in-engine.html
2000 Dodge Ram 3500 Cummins Diesel: Oil Leak
issues?
http://schematicsdiagram.blogspot.in/2012/06/2000-dodge-ram-3500-cummins-diesel-oil.html-----------
These will help.Thanks.
