Question about Zyxel Prestige 660R Router (P660R)
P-661H-D3 zyxel problem?
Hello,we have a P-661H-D3 zyxel, while everything was fine for about two years or more, it's been two weeks now that we have no Internet at all. While the dsl light is on and green, the Internet light is off.The status says that DSL is up at 37 kbps / 42 kbps and ATM loopback fails. Also, WAN has no ip (0.0.0.0) Is it a problem of our zyxel or is it sth wrong with the line? (dslam for example)
Restarted it several times, even tried a reset and restore but nothing seems to change.
Thank you for your help!
  • 1 more comment
  • karanasou Jul 15, 2009
    Thank you for yr help,
    no I still can't connect. Right now I'm using a different default gateway than the zyxel's and I have the ability to go online. One more thing, when on wan-->"more connections" tab, I see an "Internet connection" as usually, but there are no Active or Modify icons.
    So, router is off for good???
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Check in! Bear in mind: e-mails are iffy here, just because you didn't get one doesn't mean that there is no response. Many routers default to 192.168.2.1 therefore the computer's static IP should be 192.168.2.xxx with xxx ranging from 2 to 255
    Sergeant:
  • 121 Answers
The fact that it does not get an IP address almost certainly means that the router is KAPUT. You may try to add in a manuel address. In you network settings of your computer you can put the following IP addresses:
IP Address : 192.168.0.100
SUBNET MASK : 255.255.255.0
GATEWAY : 192.168.0.1
then try to see if you can connect to the internet (see if the internet light then comes on.)
Let me know if it works. I may still be able to help you after that.....
My email = doc@plettcomputerdoctor.co.za
Posted on Jul 15, 2009
  • Johan Stoltz
    Johan Stoltz Jul 15, 2009
    Where are you ? What Country ? If it is in South Africa I may syill be able to help you by changing some settings.....
Please I want CD setup router ZyXEL MOD. P660HW-D1 .
The quick start guide for this device can be found here: ftp://ftp.zyxel.com/P-660HW-D3/quick_start_guide/P-660HW-D3_2.pdf
You should be able to do any appropriate configuration with this guide.
Good luck.
Mar 01, 2011 | Zyxel P660HW-D1 Router
How can i config a dmz on a zyxel p-660hw-d3
Go to the router's IP, put your password then go to Network, NAT, Port Forwarding and put the DMZ IP on Default Server.
Nov 05, 2010 | Zyxel Computers & Internet
How can i find my wep key for zyxel P-660HW-D3
See the attached manual and look up page 63 where is shows how to get to the wep key information.
the link is: ftp://ftp.zyxel.com/P-660HW-D1_v2/user_guide/P-660HW-D1%20v2_3.40_Ed1.pdf
If this solves your problem, leave feedback please.
Feb 06, 2010 | Computers & Internet
Wireless Problems Zyxel P660HW-D3
When you defined the name for Wireless connection with you new router, did you give it a new name? If this is a case then you can delete the old name in your available wireless network list in your lap top so it won't go back to the default one which is the old one, then you are all set.
Sep 07, 2009 | Zyxel P660HW-D1 Router
Having a connection problem with ZyXEL 660Hw-D1
Did you duy a service. If not buy one. If has have to have broadband.
Aug 30, 2009 | Zyxel Prestige 660HW Wireless Router
I have forogotten my password for my zyxel router. how can i get it or change it so that i can connect to the internet
the quickest solution would be reset the router once . Resetting the device would bring it back to factory defaults .
Hope this helps
Thanks
Ranjit ranjit@supportminds.com
Aug 11, 2009 | Zyxel Prestige 661H ADSL2+ Modem + 4 port...
Port forwarding not working in ok firmware AGL6 or later
According to my very thorough testing some weeks ago, P-660-HW-D1 port forwarding is really very broken.
The worst thing is that not only does the port forwarding work properly, it lets packets to LAN addresses where they're not supposed to go. This means you're not safe behind LAN.
Firewalled or not, AGL.6 or AGL.7 shouldn't be used at all in my opinion, they're unsafe. When in routing mode, and having several LAN machines behind one Zyxel switch port (i.e. separate switch attached), I found that the port forwarding is completely broken.
I have contacted Zyxel Finland about this issue two weeks ago, and they initially thanked for the finding and said they're passing the issue onwards and investigate it.
The best current solution is to downgrade to (also very buggy) AGL.4.
May 13, 2009 | Zyxel P660HW-D1 Router
In web config the links won't show with Zyxel P-661-HW-D3
The password that is already filled is "user" and replacing it with "1234" will allow you to enter the setup screen.
Apr 26, 2009 | Zyxel (91-004-361002) Wireless Router
Zyxel Prestige 660R Router (P660R) Logo
1,088 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
