Canon MX300 Office All-In-One Printer Logo
T
Timmy Favron Posted on Jan 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What do I do with "set value" after align print head action completed
J.D. Browning
Level 3:
  • Master 2,760 Answers
  • Posted on Jan 20, 2016
J.D. Browning
Master
Level 3:
Answers
2760
Questions
0
Helped
1013985
Points
6696
On the test print paper there should be a set of numbers there (prints automatically after align print head is done), these will need to be added into the prompt that comes up in screen after "set value" shows up, but unless a major rebuild has just been done to machine I find this is rarely needed to be done < I just select skip or done to exit that mode
Printer head alignment
Print Head Alignment For Canon printer For more details visit this website: https://www.errorsdoc.com/canon/
Open the printer driver setup window.
Click Custom Settings on the Maintenance tab.
The Custom Settings dialog box opens.
Switch head alignment to manual.
Check the Align heads manually check box.
Apply the settings.
Click OK and when the confirmation message appears, click OK.
Click Print Head Alignment on the Maintenance tab.
The Start Print Head Alignment dialog box opens.
Load paper in the machine.
Load three sheets of A4 size or Letter size plain paper into the rear tray.
Execute head alignment.
Make sure that the machine is on and click Align Print Head.
Follow the instruction in the message.
Check the printed pattern.
Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
When you have entered all the necessary values, click OK.
Note:
If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
(A) Least noticeable vertical streaks
(B) Most noticeable vertical streaks
If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
(A) Least noticeable horizontal streaks
(B) Most noticeable horizontal streaks
Confirm the displayed message and click OK.
The second pattern is printed.
Note:
The third pattern is printed.
Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
How do i re align the head on aMX432 cannon
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
  4. Apply the settings
  5. Click Print Head Alignment on the Maintenance tab
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
  8. Check the printed pattern
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
  9. Confirm the displayed message and click OK
  10. Check the printed pattern
  11. Confirm the displayed message and click OK
  12. Check the printed pattern
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
2helpful
Hp 8500 printer stuck in continuous cleaning and alignment loop after replacing cartridge
Printer wont do the alignment process if we replaced the cartridges, might be removed/re inserted the printer heads, then ply it process the alignment, if the print head nozzles are clogged, alignment process wont completes..
>Remove the print heads clean the nozzles with tissue paper gently at nozzles.
>borwse this link & see how to clean the print head,link:http://www.youtube.com/watch?v=ZAwYIbjswV0&feature=related
>Install the printer heads do the alignment..
> if not completed check which printer head clogged, replace the print head.
HP Officejet Pro L7780 all-in-one, Windows Vista, set up as a wireless network printer, prints multiple copies of test page and also other documents, when only one is selected both at the computer and...
this is a simple problem, the technology that printer aligns its print head automatically by the reading the align page, if your printer head are not in good health/clogged align print wont come properly result align pending..When printer gets power on its prints align page till align completes. Go to tool box in system all programme, perform clean print head, check the quality of printer outs then ask to printer to align.. if its not completing replace print heads..
11helpful
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
  9. Check the printed pattern
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
  15. Check the printed pattern
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
MP970 Photo All-In-One InkJet Printer: The printer head alignment is off. I have tried to...
  1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette.
  2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension.
  3. Press the Paper Feed Switch to select the paper source where you have loaded paper.
  4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
  5. Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
  6. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
  7. Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
  8. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
  9. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Canon i960 printer banding on photos. How can I eliminate this? I have cleaned the print head, re aligned the print nozzle. Now what?
The FAQS for your printer suggest for your problem (banded or strewaked prints) you perform this actions:
  • Perform a manual print alignment
  • Perform a deep print head cleaning
  • Check if all orange tape was removed from print ink tank(s)
  • Select correct Media Type Settings for the paper you are using
  • Change the print quality settings.
If you need guidance on how to perform any of these actions, go to the support page of your printer:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=103&modelid=9388
and in the "Please enter your question..." textbox type "banded printing".
After printing he print headaliengment
Greetings!
I dont know the kind ot printer that you have, but that happen when the printer was set to that setting. Just open the printer icon/setting then properties find the setting and removed that kind of action.
Thanks
Will it mess up my printer if i pulled the paper out
No. But, do this while the power is off. And get a firm grip on the center of the paper and pull with increasing constant pressure until the paper come out. You don't want to risk tearing the paper. Should that happen, open the cover and see if you can't pull it out backwards. In fact, if there is more paper stickng out the top than the front, pull it out from that direction.
After you get the paper out, remove the paper from the feed tray. Turn the printer on and let it go through its startup diagnostic (that's what all the commotion and noise is about when you turn it on.) Once complete, add some paper to the tray and from either the LCD Panel menu options, run the print head alignment test and set the values according to what lines line up exactly and punch those numbers in. The print head alignment test may also be available to you from the printer's program menu tools or from the Start Menu, Printers and when your printer shows up in the box, right click your printer, choose Properties and there may be a set of tools from there that will run the print head alignment test.
That's the long and short of it, Yes, pull it out from above, from the feed tray or from the front, whichever has the most paper exposed. Then run the print head alignment test to reset the alignment.
Regards,
Worldvet
old marine
old marine
ZJ Limited
ZJ Limited
