Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture has a blue lines and has a violet color at the center.
  • 44 Answers
The circuits that drive the picture tube are called demodulator circuits. Trouble there will give you those symptoms. This is repairable. Also it may be the picture tube itself. You need to take it to a repair shop to find out, since a bad picture tube is cause to throw it. ----- Eagle2
Posted on Jul 17, 2009
I need the wiring color coding of jvc kd-r526
All branded car stereo system color cods are same. FR-speaker:brown,brown with black. FL-speaker:white,white with black. RR-speaker:violet,violet with black. RL-speaker:green, green with black. Yellow:battery. Red:key main ( acc). Black:ground. Blue and blue with white: amp remote or power antenna. Thanks.
Nov 29, 2013 | Car Audio & Video
I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Aug 21, 2011 | Car Audio & Video
Need a radio wiring diagram for a 97 Nissan Altima i found one on line but it wasnt nothing like the colors of the wires in my car.
red = 12v ignition/acc
yellow= 12v battery/memory
black = ground
blue = power antenna
blue/white = amp turn on
black/white = amp ground
orange = illumination
orange/white = dimmer (+)
orange/black = dimmer (-)
brown = mute phone
speakers---
grey = right front positive
grey/black = right front negative
white = left front positive
white/black = left front negative
violet = right rear positive
violet/black = right rear negative
green = left rear positive
green/black = left rear negative
Dec 30, 2010 | Car Audio & Video
Wire color abbreviations Isuzu Rodeo
P - Pink
LB - Light Blue
V - Violet
GR - Grey
LG - Light Green
BR - Brown
L - Blue
Y - Yellow
O - Orange
G - Green
R - Red
W - White
B - Black
Some wires will be allocated 2 colors ie B/W. This is a color with a different color line running along its length.
The first denotes the main color (Black in our example) and the second denotes the tracer line (White in our example)
Sep 09, 2010 | 1992 Isuzu Rodeo
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
The dark color of my tv was change unspected the dark color now are blue, violet,and other exept black, the dark scense can't see. please help me.
I believe you either have a bad LCD Controller Board or a bad Main Board. The only way to know is to replace one. If it doesn't fix it , replace the other. Or replace both and it should be fixed.
I hope this helps,
Skyassoc
Nov 03, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
I just bought a used dual xd6210 stero deck for my car but i dont have the wireing manual for it. i need the wire color code sheet
there pretty simple red+ goes to keyed power wire. yello is the same keyed power wire.black ground. speake wire will be like two green two violet one will have black stripe that is the negitive solid color is positive green and green violet ant violet white and white blue and blue youll just have to figure out thr front and rear. blue wire is for amp remote turn on wire your speaker wires may be different colors but same idea
Jun 10, 2009 | Dual XD6210 CD Player
What color are the wires for the iat sensor on a 2009 f-150 w/ 5.4 l
the iat is part of the maf sensor located in the air filter duct or housing. 6 pin connector. pin one color violet/gray is for iat. pin 2 is c-signal rtn yellow/violet. pin 3 maf yellow/violet. pin 4 maf rtn blue. pin 5 ground black/yellow pin 6 circuit breaker fuse 76 blue/brown
Mar 05, 2009 | 2009 Ford F-150
Violet screen on kodak m753
Check the White Balance setting. If it is on Tungsten or Bulb, put it on Auto.Also check if the lens is clean. Use a dry cotton cloth to clean the lens. If this fails to solve the issue, take it to the nearest authorized service center.
Feb 10, 2009 | Kodak EasyShare One Digital Camera
Blue violet ghost
did you just replace your lamp? your balance is probably off.
Jan 31, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
