Question about Veo Connect Webcam
My Connex 3300HP-ZX Turns on & lights up, but seems not to transmit or receive.
Connex 3300HP-ZX lights up, PA works OK, Meter works, channel selector ok but display drops number segments. Doesn't receive or transmit; external SWR meter works so is putting up carrier (I think). inside LOOKS ok - nothing obvious. Been a HAM for many years, but no 10 meters. Bought this radio really cheap, so can put some $ into it, but not a lot. HELP.
Why doesn't it transmit or receive?
Did you replace any components such as the audio chip,the audio cap.near the modulation transformer ? Could be the final or even the driver .Did you follow a service manual as to how to re-tune it ? Eliminate the positives to find the negatives.
Mar 11, 2016 | Connex 3300 HPB 10 Meter Ameteur Radio
Connex 3300hp not receiving at all rx tx light on front not on, key mic turns red
MAKE SURE ALL THE CONTROLES ARE SET CORRECTLY R-R GAIN CLOCKWISE FULLY, SQUALCE COUNTER CLOCKWISE FULLY AND HAS THE RADIO BEEN MODIFIED FOR THE 11 METER BAND BY SOMEONE
Feb 25, 2013 | Connex 3300 240-Channels Base CB Radio
I have cobra 29 LTD that will power up, but wont talk or receive.
First make sure the switch on the front is not set to PA or Weather if the unit has the weather featurre.
Then look to see if the receive/transmit meter is showing any movement in either mode.
You had a Connex board installed? I bet that is wired wrong or a wire came off in the process
Do it yourself installation or a "expert"?
Dec 07, 2012 | Cobra 29 LTD CB Radio
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
My connex 3300 wont transmit anymore and the talk back wont work either,i have tried a different mike and when you key it up the meter still won't swing.
Plug in an external speaker to the pa jack ... Switch the band selector to pa and see if you hear yourself... No? Bad audio chip
Dec 29, 2010 | Connex 3300 240-Channels Base CB Radio
My connex 3300hp just stopped transmitting. why? it has power and i hear myself from the speaker, though no one else can hear me.
The RF final output transistor(s) is probably blown. They are not very difficult to replace if know your way around with a soldering iron.
Oct 09, 2009 | Connex 3300 240-Channels Base CB Radio
Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
Aug 26, 2008 | Connex 3300 240-Channels Base CB Radio
Veo Connect Webcam Logo
111 people viewed this question
Top Veo Computers & Internet Experts
Thomas F. Schneider
meli novacole
Level 1 Expert
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
