Question about Sewing Machines
We have a whirpool Gold ultimate care II electric dryer. It will not completely dry clothes in one cycle..sometimes it takes 2 or 3 cycles to completely dry even though the dryer chamber has very hot air. I have already cleaned out the filter and filter/blower shaft and pipe to outside. There is nothing blocking it. Is there a sensor, etc. which could be causing it even though there is sufficient hot air?
  • 4 more comments
  • chc1jack Jul 15, 2009
    How do I run it without the sensor?
    That is what we always do normally....run everything on a timed dry setting with the temperature setting on "Heavy High) and with the Finish Guard Plus"OFF"...should the finish guard plus be "ON"?
    I'm doing what you suggested however I don't think I need to wait until the end of the drying cycle. I turned off the finish guard (which is the way we always run it) and unhooked the venting...There is a hugh blast of hot air shooting out the back and the blower seems to working well. What else could be doing it? How does the sensor impact the drying time, etc? If it is the sensor how can I get the part.
    I thought the sensor was immediately behind the back panel??
    Is that now the logical problem?
  • chc1jack Jul 17, 2009
    turns out we fixed it..........not with the electrodes but following your step by step procedure we finally determined the vent was blocked up in the attic. purchased an 18' flexible lint brush and cleaned out venting. thanks
  • 441 Answers
If you have already cleaned the duct work try to run a load without using the sensor, if the problem is still happening then it is not the sensor. Also run 1 load with the vent unhooked, if this does the trick it is a venting issue. A venting issue is not just lint buildup it could also be a issue with the blower.
Posted on Jul 15, 2009
  • 5 more comments
  • John Riley Jul 15, 2009
    use the "time dry" settings, this setting just runs on time & does not ust the sensors.
    I would set the finish guard to off, unhook the dryer from the venting and run a load thru. We know the dryer is heating so the problem has to be venting or temp sensor. Let mr know what happens after the test cycle.
    To get a replacment sensor go to marcone.com all you will need is your model #, It sounds like the blower is working, let it finish the cycle just to be sure, you will get some good diagrams on the web site this may help with taking it apart, start by taking out the screws on the top of the dryer door opening, then remove the screws from the back of the backsplash, you will then be able to take the top off and get to everything.
    the drum sensor is located just inside the door to the left, it looks like 2 silver bars about 4" long about 1/2" apart, you will need to pull the door off to replace them
    If you got the same results as before after running a load with the venting unhooked then yes that is the problem.
  • John Riley Jul 17, 2009
    Have you had any luck getting the dryer running?
    Good deal, Glad I could help
    Go Cubs
We just purchased a used 1036,and the needle hits when going down so it will not complete the cycle.Cannot seem to find problem.
If you have installed a brand new needle and the problem continues, the machine has been knocked out of time. Search for sewing machine timing or take it for service.
Mar 15, 2017 | Sewing Machines
Replaced broken needle clamp, but presser foot blocks needle shaft from going all the way up & the drive wheel cannot complete a turn to pull thread.
I'd need to know what type of machine you have, but maybe you aren't putting the clamp on correctly. They are fussy! Be sure you have the flat side of the needle facing the correct way and that you wiggle and jiggle it while pushing up on the needle. Also, make sure you are using a new needle and not the old bent one. Sometimes the clamp will come in 2 pieces, so it may not have broken, just came undone.
Dec 30, 2015 | Sewing Machines
Sewing machine in loft for 25 years.Electric is there but doesn't turn and only half way manually.Foot bobbin & feeder don't move electrically but they do slightly manually. A drop of oil or a fix?
I've restored a number of machines that had been stored for years, so, here's the general procedure to do it yourself:
1. get some denatured alcohol and a clean low-lint rag (it will get *dirty* so nothing you're planning to use elsewhere), an old T-shirt is great.
2. get some good quality sewing machine oil.
3. get some basic tools - screwdrivers, pliers, etc.
4. You're going to want to avoid distractions for a while, so find a quiet place to work, this should take 1-2 hours.
5. Take the machine covers off - how to do this varies from one machine to another, but it's usually fairly obvious. Be sure to put screws you take out aside where you won't lose them. Be sure you open up the bottom as well as the top... the bobbin should be removed for this procedure, too.
6. Clean the interior parts you can with the alcohol and rag, being careful not to leave bits of rag in the mechanism.
7. Let it dry as you move on to another area.
8. Lubricate! Oil and more oil *Not* just a drop or two, pour it on pretty heavy... it may even drip out but that's O.K. for now.
9. Once you've oiled pretty much everything you can see (the only thing to avoid is electrical stuff, light bulbs, etc.), move the mechanism by hand at first. It should have loosened up. If not, repeat step 8. Lubricate some more. As you're turning the hand-wheel, you'll see moving parts move, be sure that they're all oiled. It can help to oil as you move as well. It's really hard to use too much oil.
10. Once you've got it turning freely by hand, try it on the electrics. If all works well, proceed to close it up and clean the exterior with the alcohol and cloth. This will also clean up any oil you've spilled or dripped.
11. Sew on a 'test' swatch for a while as you'll probably get oil coming out for the first 10 minutes of sewing time or so.
Apr 03, 2015 | Sewing Machines
Can I get a manual for Kunft 410/01?
You should have a troubleshooting section in your operating manual that will help you know why it may not be running. All machines are programmed NOT to operate if doors are not closed completely. You may not have the selector completely dialed onto a wash cycle, sometimes I dial mine into the off section just before the actual wash cycle begins. Could be your breaker has tripped that feeds the current to your washer. Go to your breaker box and see if the washer has a breaker all of its own and flip it back and forth to be sure it is on the ON position! Sometimes different areas of the washer dials do quit working and must be repaired. Try more than one area on the dial...permanent press, casual, normal.
Jul 07, 2014 | Sewing Machines
How To Clean Silk
Hand Wash the item. Gently move the silk fabric around in the soapy water. Rub stains with your fingers or a sponge to clean them. Pour the water out when finished washing your garment.
Rinse the silk garment in a vinegar solution. White vinegar removes soap, restores shine and softens silk. Fill the basin with cold rinse water. Add 1/4 c. (50 ml) white vinegar. Gently move the garment around in the water to thoroughly rinse it. Empty the basin again.
Rinse the item in cold water. Add cold water to the basin. Rinse the silk item a second time in a basin of fresh, cold water. Turn the garment over and around to ensure it is completely rinsed and free of soap.
Sep 16, 2013 | Sewing Machines
Why does my T500 sometimes stop
if the machine has been sitting for awhile and you oiled it that will
help, it could be the belt is too loose or the motor is going out or the
foot pedal needs to be checked to see if something is wrong with it.
it would be a good idea to have the machine checked at a sewing
machine shop.
Oct 18, 2012 | Tacsew T500
Commerical washer leaves too much water in clothes after spin cycle. its a whirlpool
Hi, please try and check the pump.I suspect it is blocked which prevents the flow of water. Sometime small clothes like socks blocks it...
Feb 19, 2010 | Sewing Machines
The sensor in my dryer has become loose and is not drying clothes completely. Can it be replaced?
If you still have the manual for the dryer, look in the parts section for the sensor part Number and call the service dept. number to order the part or call customer service. I replaced the one in my sears dryer. You can also find info at the library, Readers Digest ( FIX-IT-YOURSELF-MANUAL ). it's not hard to replace. Hope this helps!
Nov 29, 2009 | Sewing Machines
I have a kenmore elite that i am getting a f code no numbers just f. the book tells me it is not getting the right power what can i check ? it washs sometime but sometime it stops and beeps.Had a flood can...
Suspect that the controller got wet. Pull the power cord. Remove the controller, place in a dishwasher by itself and fun a cycle with dishwasher detergent. If there is a relay on the board, it must be removed before the wash. After the wash, thoroughly dry the unit with hot air from a hair dryer or similar. Reinstall and try the washer again. If no success, you may have to replace the controller.
Nov 28, 2009 | Sewing Machines
Bobin thread will not catch on manual cycle.
Your machine is out of time. You will need to take it to a good repair shop to have it timed. Make sure your machne is all cleaned and oiled or they will charge you to do that too.
Aug 18, 2008 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
