Question about Whirlpool Dryers
Gas dryer not heating. Drum does turn. Tim,er
Gas dryer not heating. Drum does turn. Timer appears to be working.
  • Whirlpool Master
  • 1,606 Answers
The dryer has a bad thermal fuse . A small slim white piece with 2 wires attached . IF you do not see the glow from the ignitor .
Posted on Jul 19, 2009
The timer stoped working and there for no heat but the drum turns
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | Dryers
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
110 74202200 Gas Drier will not heat.Blower works, Drum Turns, Vents all clear. Checked Gas line Gas getting to Drier. Looked at burner: It is clean, no rust, no corrosion, Wires in good shape. It appears...
heatman101
Mar 31, 2011 | Kenmore Dryers
I have a Roper gas dryer (RGS7646KQ2) which is not heating up to dry clothes. The drum turns and the timer works as well. It appears to be acting normally, except it is blowing cold air instead of warm...
You have a bad thermostat, flame sensor, thermal fuse, gas valve solenoids, or the high limit thermostat. Below is a video to walk you thru the diagnostic testing and repair.
Jan 03, 2011 | Roper RGS7646KQ Gas Dryer
My dryer drum turns but dryer does not heat up and the timer never moves from starting point
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Dryers
Amana dryer, no heat, drum turns, timer not advancing
heatman101
Dec 13, 2010 | Amana DLE330RAW Electric Dryer
Kennmore dryer wont heat
Your problem could be one of the following:
* thermostat
* gas coils
* radiant sensor
* gas igniter
* timer
Contact an appliance service company.
Feb 20, 2010 | Kenmore 93142 Gas Dryer
No heat drum turns no heat blower works no heat
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Feb 01, 2010 | Dryers
My dryer squeeks when running
Hi, I've had a similar problem (I think) on my MDG7400 dryer. There was a cyclical squeak, metal against metal. It turned out to be the screw that holds the drum paddle to the drum. It had worked itself loose and was scraping against the inside wall of the dryer. Remove the front door lift the top, and tighten 'er up. Hope that helps.
Nov 19, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
