Heating & Cooling Logo
Stanley Lanham Posted on Jan 20, 2016
What size battery does it take - Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
What size battery does it take for a Honora watch?
The size of the battery required for a Honora watch will depend on the specific model of the watch. However, most Honora watches use a standard watch battery known as a silver oxide battery or button cell battery. The most common size used in watches is the 1.55 volt button cell battery, which is also known as the SR626SW battery or the 377 battery.
To ensure that you purchase the correct battery for your Honora watch, it's always best to refer to the owner's manual or contact Honora's customer service for more information. Additionally, many jewelers or watch repair shops will have the necessary batteries on hand and can assist with battery replacement if needed.
1helpful
What size battery does my Emporio Armani AR-5331 take
The size of the battery that your Emporio Armani AR-5331 watch takes will depend on the specific model of the watch. Some common sizes for watch batteries include:
  • CR2032: A small, coin-shaped battery that is commonly used in small electronic devices such as watches and calculators.
  • CR2025: A slightly smaller version of the CR2032 battery, also commonly used in watches and small electronic devices.
  • CR2016: An even smaller version of the CR2032 battery, also commonly used in watches and small electronic devices.
It is best to refer to the user manual or contact the manufacturer to determine the correct size battery for your Emporio Armani AR-5331 watch. Using the wrong size battery can damage the watch or cause it to function improperly.
2answers
What size battery for a 1998 dodge dakota v6 pick up truck
Size 24 or 27. I found this on the AutoZone website. You can too.
1helpful
What size replacement battery do i need to but?
it depends up on the size of your vacuum cleaner.A range of 12v batteries are available and this battery is for only small size it varies with size to size.
Custom Car Body Kits
Jun 15, 2012 • Vacuums
1helpful
What size batteries do i need for 96 canter fe211
GO TO ANY AUTO PARTS PLACE TELL THEM YEAR MODEL TYPE OF CAR.WHAT ENGINE SIZE AND TYPE FUEL INJECTION SYSTEM.THEY WILL LOOK UP WHAT BATTERY SIZE YOU NEED.
3helpful
2answers
Need battery size for 1996 Dodge Caravan
your cars battery might only need charging or battery acid replacement, but if you'd realy wish to buy new one, buy one with the same size and voltage and amps as the one you have right now, or you could buy a battery with the same voltage with a higher amppere-hour (Ah) rating!
3helpful
2answers
Need size of battery for 2000 ford focus
Dependant on engine size and fuel type, any size from a 390 amp battery, if it is diesel then a 590 amp battery. No special tools needed, only a small ring spanner. Make sure yyou disconnect the earth lead first. Also you will need to enter the radio code after changing batteries
What is size of replacement battery for 2000 sonata v6?
Size 75 was the standard battery many of the newer size 75's are actually stronger than the old 78's, so you can probably get away with a 75 which is a little smaller and lighter.
1helpful
Need to know the physical size of a battery for a 1996 Cherokee.
Your Jeep Grand Cherokee uses a group 34 type battery. The sizes vary from manufacturer to manufacturer but, the standard size is 10 1/4 " x 6 13/16" x 7 7/8" or 260mm x 173mm x 200mm. Anything close should fit fine. Good luck. Please ask for help any time. Please rate me so I know how I'm doing. Thanks
Batteries
The E-10/20N battery holders are designed to fit the longer type CRV-3 lithium batteries and conventional sized AA NiMH batteries. Once installed into the battery compartment the AA sized batteries will make an electrical contact with the camera
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
