If you're getting a AC error light, but you're sure the compressor works, you need to reset the compressor. Disconnect the battery for 20min (keep in mind, this will reset everything). After 20min, reconnect the battery. When you turn on the AC, the light shouild go out (AC error light). Be ready to add freon right away or the compressor will shut down again. Post back if you need instructions on adding refrigerant. Best of luck.
Greg
If you buy the cans from walmart the instructions for that are on the can. It is very simple though. Just turn the car on with ac on and compressor will engage unless there is a problem with it.
