Question about Nokia 3110 Cellular Phone
My 3110 & N95 keeps going off most times when I just put it on
I tried putting on my 3110c on at time and it will just go off but only to come on after sometime of several attempts. On the other hand, my N95 goes off badly that I am hardly able to make use of it
3110c bilinking three time then off. which solution there tell me ple
During The End Of First Blink Take Your Battery Out As Fast As You Can......Then Put The Battery It Will Turn On.......My 3110c Also Had The Same Problem.After I Did That It Worked Fine!!!!
Dec 15, 2010 | Nokia 3110 Cellular Phone
Hi, i want to hard format my nokia 3110c, pls help me
hi, i want to hard format my nokia 3110c, pls help me. phone off and bifor on time nothing masseg & wolpaper what to do pleas send me
Sep 27, 2010 | Nokia 3110 Cellular Phone
Restart my 3110c nokia phone how to format my phone with install any software
my nokia 3110 is not starting upp.whenever i try to switch on the phone a light blinks 3-4 times and than again it switch off.. so what should i do
Feb 19, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Nokia 3110c problem
just try this one.hope this help tested many times..just! LONG PRESS KEY *, 3, SEND,& POWER ON..together?
Aug 15, 2009 | Nokia 3110 Cellular Phone
I forget security code
stape - 1
plz remove your mobile battery so some time
statp -2 install nokia pc shuit and coneecte mobile
go www.isohunt.com serch mobile unlock software download
try.... your problem solve
Stape::::--- 3 type your mobile screen *#7780# Continue Plz wait.....
........ enjoy.......... more details Mayur:::::::::pandya::::mo::: 9974892930
Aug 12, 2009 | Nokia 3110 Cellular Phone
Nokia 3110c restarting problem
i,am **** that u have same problem with new phone also..normally i found that problem on n95
i think u sould reset ur all phone setting...
or go to the repair center and ask for flash to ur phone...
gud luck
Nov 10, 2008 | Nokia 3110 Cellular Phone
Lock Memory Card In 3110c
me jab memory card lock opction per passward daalte he to wo lock nahi hota please help me ki use lock kese kare
Jul 15, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 classic
Solution 4 Nokia 3110c Restart
Those who still have this restarting problem on Nokia 3110c ... Im telling the solution again, step by step.
If
method
4] Then you must restore Factory settings from the Settings Menu
6] Now
ur phone
9] Switch On
Feb 11, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
