Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Power light flashing
I used to have the issue where the monitor would take a while to display anything and then start flickering and eventually turn on. Now, i came home and the power light quickly flashes and nothing displays at all. I have taken the monitor off of the computer and simply plugged it into a different power source with the same result. When I take it off of the power source by either toggling the power button or removing the power cord, the light continues to blink but slowly fades to off. I'm thinking it's a good excuse to upgrade my monitor but if i can fix this one, why not?
  • Samsung Master
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 17, 2009
Have emachines monitor which is not coming on power button fast flicker
Which power button is flickering (your computer, or your monitor).
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | eMachines Computers & Internet
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
My samsung Tablet's Screen keeps flickering continously
Good luck.
Jul 07, 2014 | Computers & Internet
SAMSUNG TMS22WS Flickering Picture
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Computers & Internet
Screen is blank
Hello
The issue might be that your monitor is not getting enough voltage to turn on properly.
If the monitor is plugged into a surge protector, remove it and plug it directly into the wall outlet. If the monitor works fine, the surge protector is not allowing enough power thru it for the monitor to work correctly - replace the power strip.
If there is no change, then your monitor is going out.
Dec 03, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Monitor flickers unless brightness is at 100%
Try monitor menu select Memory Recall and press that, should clear right up
Mar 08, 2009 | ViewSonic VA1912wb Monitor
Monitor took half an hour to warm up, now won't start.
doubtful this is a driver issue warm up is not needed for any monitor. this is a power board issue internal to the monitor capacitors or some issue on the main power board. let me kow what you will do. good luck.
Nov 18, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Gateway Flat Screen FPD1830
Well, this problem is going to only get worse. You can probably send it back to the manufacturer if you still have a warantee, but if you can't just buy a new monitor.
Nov 13, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
362 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
