Player asks me to enter calibration on switch on
  • 3 more comments
  • mshirley8 Jul 15, 2009
    SCREEN IS BLANK ON SWITCH ON AFTER TELLING ME TO CALIBRATE
    PLAYER HAS BEEN WORKING OK FOR MONTHS I AM VISITING USA . NO DISC SCREEN BLANK
    PLEASE HELP
    TALKS TO COMPUTER OK VIA USB
    THINK MODEL IS DU07 1936 BLACK
    President:
  • 2,777 Answers
That model number doesn't pull anything up, must be something else. It sounds like you have experienced hardware failure, you will want to check with the manufacturer to see if it is repairable. Feel free to reply back with the actual make / model number if you can find it.
Thanks
Tim
Posted on Jul 15, 2009
  • 3,741 Answers
This is a normal procedure.when the screen becomes non-responsive the calibaration is required --------
For the first time to use this MP3/4 player, please calibrate your TOUCH SCREEN to make your touch experience better. Please switch on your MP3/4 player, touch the Settings Icon, enter the settings mode, then choose" system settings" and enter. Choose the “Touch panel Calibration" Function. Please touch the center of the red cursor, and follow the movement of the red cursors to
Adjust your MP3/4's TOUCH SCREEN till it finishes. You may need to calibrate the screen in couple of months’ time if you feel the screen is not so responsive.
this will help.
thanks.please do rate the solution.
keep updated
Can you calibrate a boss bv9055 touchscreen
Hello there ,
It depends on what you mean by 'calibrate' meaning . The ability to precisely adjust to known values.
Audio output,, size, video, speaker calibration ?
If it isn't in the manual, it doesn't do it friend.
The free manual is via here. just enter the 5 digit number captcha when asked.
http://www.retrevo.com/s/Boss-Audio-BV9055-Car-Videos-review-manual/id/17601bh634/t/1-2/
Sep 20, 2014 | GPS
Tip
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Samsung LA32A450 32 in. HD-Ready LCD TV
I cant watch any dvds on my dvd player as their is a parental lock on there, i have tried unlocking it but i need a code which i dont have, the model is a sony RMT-D175P
OK - to switch off the parental control on the Sony DVP-NS15 and reset the password, please do the following:
1. Switch on the TV and the DVD player
2. Set the TV to the correct input for the DVD player so you can see the on-screen menu
3. Remove any disc from the player and close the disc drawer
4. Press the DISPLAY key on the Sony remote control to open the on-screen menu
5. Use the DOWN arrow to highlight the disc and padlock (parental control) then press ENTER
6. Use the DOWN arrow to highlight ON> then press ENTER
You will be asked to enter a password. Press 1 9 9 7 0 3 then press ENTER. Don't worry that it's only asking for four numbers, you need to enter all six. After you enter the master password, you will be asked to set a new password. Set this to something easy to remember, e.g. 0000 then press ENTER and confirm the password.
Finally, if you don't want to use the parental control feature you need to switch it off. If asked for the password again, enter the new password you set.
7. Use the arrow keys to highlight OFF> and press ENTER
8. Press the UP arrow to highlight PLAYER> and press ENTER
9. Highlight LEVEL and use the arrow keys to set this to OFF
10. Press the DISPLAY key again to close the menu
If you have any difficulty unlocking the player, please let me know.
Apr 05, 2011 | Televison & Video
My Zebra printer is eating labels on and off. I feel when the printer runs out of labels it losses the labels and never prints it again when the Labels are reloaded. Is there a configuration setup for the...
is possible calibration issues. please run manual calibration,
go through the setings and run MEDIA and RIBBON CALIBRATION.
if ask to load labels,
open printhead, take 2-4 labels from the back papel and load the back paper normaly.
then press enter. Ask for REMOVE RIBBON? open printhead and move the ribbon from left to the rigth of the printhead (remove from the sensors(left and side)) press enter.
let the printer save that figers from the sensors (back paper/no ribbon)
LOAD MEDIA?
ok, put all back on normaly (labels and ribbon set up proply) press enter.
The printer going to run the calibration, if stop on the gap?! save (press twice on SETUP Button.
SAVED? OK. turn of and turn on again, send the job.
Hope help. Rate please. Thanks.
Dec 17, 2010 | Zebra Z4Mplus Label Printer
My printer shows an error of platen cal cable.How can I solve the problem
Hi
platen calibration has to be done . in offline press lf and enter for tech access on , then go to test menu, select diag,then select call engine , then select platen cal and press enter , it will ask remove ribbon and remove paper , then it will automatically calibrate . then ur problem will be sloved
Hope it can resolved issue Thanks you for using Fixya
Mar 22, 2010 | Tally 6312 Matrix Printer
I have a line matrix printer lipi 6306L. When I switch on the printer it shows a fault : Platen Cal Cable How to solve it
Jan 25, 2010 | Tally 6312 Matrix Printer
Touchscreen
try calibrating the unit
Oct 17, 2007 | Pioneer AVIC-N1 Car DVD Player
Avic d1 touch screen issue
The touch screen calibration is of, the screen has to be changed.Its 200$ from pioneer or you can look on ebay theres a place in ct. that will do it for 125
Sep 28, 2007 | Pioneer AVIC-D1 Car Video Player
DVP-NS300
I'm guessing that you suspect the laser is dirty because it's having a hard time reading (or gives you the C;13;00 error).... It's not. The motor that spins the disc has defective brushes (a VERRRRRYYYY common Sony problem). They only sell the motor as part of the laser assembly for about $80. :( sorry!
Sep 11, 2007 | Sony DVP-NS300 DVD Player
"No Disc"
Here are a couple solutions:
How To Recalibrate DVD Player
Summary:
For those that are having the skiping up and unreadable disk problems try the following calabration. I did it last night and now my DVD's are much clearer and I'm hoping the skiping problem is gone.
For those that have the lip sync problem Sony should cover this for no charge, you just need to push them a little. This is a firmware update, have a look at the other posts at this web site to find the firmware revision that you need.
HOW TO PERFORM THE CALIBRATION
Make sure that the DVD player is turned OFF and in the stand-by mode with the little red LED glowing above the on/off button.
To enter the service mode/test mode, press Title, Clear, and Power on the remote.
This will produce the following menu:
Test Mode Menu
0. Syscon Diagnosis
1. Drive Auto Adjustment
2. Drive Manual Operation
3. Mecha Aging
4. Emergency History
5. Version Information
6. Video Level Adjustment
Exit: POWER Key
What each item does;
Syscon Diagnosis = Leave this for service technicians.
Drive Auto Adjustment = Automatically calibrates DVDs and CDs.
Drive Manual Operation = Manually calibrates DVDs and CDs with prompts for permission to skip, execute and/or proceed after each adjustment is made or skipped. Offers a fascinating look at all of the many adjustments made, but this method is time consuming.
Mecha Aging = Allows auto repeat mode for testing purposes.
Emergency History = Shows the number of hours on your machine.
Version Information = Shows firmware version.
Video Level Adjustment = Test pattern.
Press #1 (Drive Auto Adjustment) on the remote and the following menu will appear:
0. All
1. DVD-SL
2. CD
3. DVD-DL
4. SACD
Exit: RETURN
Press #1 (DVD-SL) on the remote and insert a Single Layer DVD when the drawer opens.
Even though you may be interested in calibrating only a dual-layer DVD, do not skip the single-layer calibration procedure. For some reason, the player prefers to first calibrate a single-layer DVD before proceeding to a dual-layer disc. Error messages may result if the single-layer calibration procedure is not performed first.
Press the enter key and the machine will begin to calibrate all of the playback features. When calibration is completed, follow the onscreen instructions to return to the above menu.
When the Drive Auto Adjustment menu returns, press #3 (DVD-DL) on the remote and insert a Dual Layer DVD when the drawer opens. Follow the instructions as noted above.
When calibration is completed, follow the onscreen instructions to exit from the Test Mode Menu. Now you can turn the player back on and try your dual layer discs to see if the layer change has improved.
If you have any concerns about trying this service mode calibration, leave it for an authorized service facility
Other solutions:
1. To reach this test menu on a DAV-S300, press and hold the "STOP" and "Muting" button on your DVD Player (not remote) and turn the volume nob clockwise about 180 degrees. You will see a flicker. A blue test screen will appear, allowing you to calibrate your DVD. Please note that if you have no technical experience, messing around in this menu can cause serious damage to your DVD. The calibration option will be under: option 1, Disc Drive Auto Adjustment (or words to that effect). Be sure to calibrate a single-layer disc first, then dual layer -- you need to calibrate both types. Good luck.
In order for the STOP + MUTE + VOLUME sequence to work, your player must be ON, but have no disc present. You need to empty the tray, power off the S300 and power it back on. Wait until the INSERT DISC/NO DISC prompt appears. Then try the SMV sequence. And you must use the buttons on the unit, NOT on the remote, to enter the service menu. Once in the menu, use your remote to select the auto calibration menu and go from there.
2. This will fix the C 13:00 problem on any Sony DVD player.
With the machine turned off on standby, press the following 3 buttons
on the handset, in order: TITLE CLEAR POWER. The Diagnostic Start menu will come up on the TV. Select the appropriate button number for "auto adjust". The
machine basically does it all. It asks you to select either a single
layer or double layer disc (whatever your offending disc is.) Ejects
the tray, asks you to put your disc in and then calibrates it. (It's
over in about half a second... painless) Just follow the prompts on the screen
Aug 17, 2007 | Sony DAV-S300 System
37 people viewed this question
 Grubhead
Grubhead
