Question about John Deere Garden
It will run for a little while the go dead. Acts like fuel problem. Does it have a fuel pump?
    President:
  • 1,273 Answers
Check the vent on the fuel cap. I have read several problems in this section regarding this common issue. This is the easiest thing to check, and the most likely issue, IMHO.
Regards, --W/D--
Posted on Jul 15, 2009
Odes dominator 800
Turn key and Yes pump should run then shut off.The only time i've seen new pumps continue to burn out is if All(maybe more than one) fuel filters are not replaced.Hope this helped.Richard
Apr 28, 2014 | Computers & Internet
It acts like it is running out of gas but it will almost always start right back up and drive a little farther and then do it again i put a new fuel filter on it and checked the fuel pump and it is pumping...
You need to catch your engine light on and take it to Autozone to get a code. This may let you know where the problem is located at. They test them for free. If you can't, it might be your fuel injectors possibly. Your best bet, is getting the code. You may have a bad sensor or plugs/coils.
Feb 23, 2011 | 1989 Buick Regal
A 460 engine that acts like its not getting enough fuel. Will start but runs as if only on half the cylinders missing badly or such.
Check your running fuel pump pressure. If (as I suspect) it's too low, first try changing your fuel filter. After changing the filter, recheck the running fuel pump pressure. If still low, check you fuel pump pressure regulator. If OK, you may need a new fuel pump.
Also probably would be a good idea to replace you air filter.
Jan 09, 2011 | 1990 Ford F250
Truck acts like it is running out of gas? Replaced fuel filter. Ran fine for awhile but now still acts like it is starving for fuel.
my '93 f-250 (4.9L) stopped running while driving, now it acts like it isn't getting any fuel. Tried switching tanks, but still does the same. What would be the problem.
Aug 17, 2010 | 1993 Ford F250
Acts like running out of gas then stalls.when driveing .then starts up and runs a little bit then stalls again
since no codes most likely problem is clogging fuel filter [other problems egr valve carboning up fuel pump air filter ]
Mar 01, 2010 | 1998 Ford Windstar
Car died while driving, fuse relays work, just changed spark plugs, spark plugs are gapped correctly, turns over. Timing belt is intact. Acts as if car is not getting fuel, but fuel pump is working...
Use a little starting fluid to make to the engine CAN ran for 2 second.
On high mileage car,it's possible to jump a tooth or two on the time belt (not chain).
Can you set TDC top dead center on cylinder and open timing cover to see the cam dots are lining up?
DO NOT attempt this in the dark.
Check for oil coolant cross mix.
Change fuel filter
fuel pump motor can ran but the plastic diaphragm will fall apart in a HOT DAY.
Jul 15, 2009 | 1994 Toyota Camry
Dont know whether its the fuel pump or something else
How did you determine its not the fuel pump?It could be the fuel filter but I dont think so.Your truck requires a certain amount of fuel pressure to start and a different amount to run properly.You would have to check what your fuel pressure is to say its not the pump.It should be something like 65 psi to start and 55psi to run.Even though you can hear the pump come on when turn the key it might not be putting out enough pressure to start the truck.I realize im a little late with this post but it might helpfull to others.
Feb 23, 2009 | 1997 Chevrolet K1500
2001 chevy blazer not starting
I had this same problem with my 1997 Blazer, which required a fuel pump replacement as Nitrobike said. The sign to look for is when you get in the Blazer, turn your key forward to the accessory position, but not the start position. You should hear the fuel pump charging. It sounds like a hissing or whirring noise for about 2-3 seconds while it pumps fuel into the lines to prime the engine.
Fuel pump replacement isn't cheap, about $700-$1000.
Jun 12, 2008 | 2001 Chevrolet Blazer
Garden Logo
85 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
