Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Picture too big
Example: Stats for baseball games are cut in half on top. Channel logos don't appear on bottom of screen.
  • cpbarber Jul 15, 2009
    I have tried all the settings I can possibly find on the remote. I have changed the aspect, zooms and everything I can think of. The manual has been no help. Cold it be my cable supplier?
  • Anonymous Mar 29, 2014
    data on top edge (scores, time etc) half missing during sports progs.Also sub-titles
    Sergeant:
  • 285 Answers
It seems as if your tv is in "crop", "Zoom", or "full" mode. Select letterbox, normal, or full-screen mode. Look in the manual for exact instructions.
Posted on Jul 15, 2009
Picture is to large for 27in
If model indicated here is correct either a problem in the Vertical circuit of the set or an adjustment.
Almost any shop can take the set into the service menu and adjust vertical size a bit to correct if not circuit problem.
Nov 02, 2012 | RCA F27636BC 27" TV
Watching a baseball game the stats on the top of the screen are half hidden. How do I adjust the picture size?
chang pix format it will be like full zoom 4.3 16x9 if you use a cable box check format for cable box also
Oct 10, 2010 | LG 32LG30 32 in. LCD HDTV
I have a Panasonic PT-53wx54 HDTV. The text on the ticker on the bottom of the screen that stations like CNN run is not completely visible, only the top of the letters show as they travel across the...
The set is probably in the wrong display format for the channels you are watching. Look through the setup menus for "Display format" or "Display mode". You need the menu that sets the picture for "480i", "720p", "1080p", etc. Set it for 1080p and see if that fixes it. The lower settings won't show all of the lines for a 1080p picture; they are used for old-style analog video or low-bandwidth broadcasts.
Disclaimer: this is general information and may not apply exactly to your particular model. You may still have to find your owner's manual or download a copy to find out how to correct the settings.
Oct 06, 2010 | Televison & Video
Picture is cut off top and bottom (Infocus 7210 projector)
try different ratios, also reflash firmware and lastly try new cables.
Jul 14, 2010 | InFocus ScreenPlay 7210 Multimedia...
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Digital LIfestyles 32
On your remote control you should see a zoom or picture size button. Try changing this back to 16:9. I expect that your screen got zoomed either on purpose or by accident by someone. Some people zoom in the picture to eliminate the aspect ratio areas at the top and bottom and/or sides.
This should be your problem, just un-zoom the picture
Sep 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Picture too large
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
Some Motorola Cable receivers need to be set up in the menu to go to a wide screen or zoom mode when an analog signal is detected. There may be a format button on the remote.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Oct 14, 2007 | LG 32LX1 32 in. HD-Ready LCD Television
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
645 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
