Question about Intertherm P3RA-048K Air Conditioner
Rv air keeps frezzing up and unit wont kick off like it should whats up with that guy we bought it off says he replaced the thermostat
    Scholar:
  • 91 Answers
He may not know that possibly the contactor needs to be cleaned or replaced. The points on a contactor get pitted and will fuse together. This sounds like your situation because you said it keeps freezing up, which lends toward the idea that the fan may not be staying on but the compressor is. The compressor has a distinctively low toned sound from the fan noise, If what I'm suggesting is true then you need a contactor not a thermostat. good luck
Posted on Jul 15, 2009
Turning on heater the AC unit kicks on. When using AC it won't turn off, just runs and runs and runs. Would this be an issue with the thermostat?
find where the thermostat bulb is located
if it is the ceiling or unit , it requires the unit to fill to the roof with cold air before it turns off
as most rv units are not insulated , the unit seldom fills with cold air enough to turn it off
I would get an accredited ac shop to check it out
Oct 20, 2015 | Dometic Rooftop RV Air Conditioner
Why does the Dometic 15000 BTU RV AC Unit cycle on and off in short bursts?
I had the same problem with my 2013 Alpine! I took it to a Keystone dealer and of course it wouldn't do it for them, so I contacted Dometic 574-294-2511 and asked for Al McGuire! (GREAT GUY) He is the guru of Dometic! I live 50 miles from the nearest dealer and he sent a new pc board AND a new wall thermostat to an appliance repair shop at no cost! "I" replaced them ( 5 minute job) and it has been working fine. I do keep my fingers crossed because the thermostat is terrible to program.
May 29, 2014 | Dometic Rooftop RV Air Conditioner
The Advent thermostat in our RV camper keeps giving us an E2 message...what does this mean ?? The furnace will not kick on, nor the air conditioner.
http://www.advent-air.com/media/technical%20docs/TBACE2-001%20AC%20E2%20Error%20Code%20Technical%20Bulletin.pdf
Sep 30, 2012 | Advent Analog Wall Thermostat
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
I have two Friedrich PDE15KSB-C units. When trying to turn on the heat neither will kick into the heat mode. They both blow cold air only. When they are first turned on the air blows, and there is a...
Keep +10 degree from your room temp and also thermostat in "heat" . And then check. But in your case, I think RV not energized. If no proper voltage in RV in heat mode, check the wiring to RV. If voltage in means RV not working properly. You have to change RV. Thanks.
Dec 14, 2010 | Friedrich PDE15K3SB Portable Air...
Air conditioner works fine but heat won't kick on
Check RV is working. And also keep thermostat setting +29 and heat mode.
Dec 09, 2010 | Ruud Matching Split Air Conditioner
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
Portable generator pops breaker when temp is over 75 degrees
I take it you have RV plugged into generator. Hopefully direct with no extension cords. Are you using a 30 to 15 amp adapter to plug into generator? What is the rating of the breaker on the generator that keeps tripping, suspect it's only 15 amp?
Jul 20, 2009 | Dometic Rooftop RV Air Conditioner
It wont cycle on and off and is frezzing up
one of two things could be the problem. Check to see there isnt any blockage to the coils i.e. dirty, secondly, It sounds as if your unit is low on freon.
Jul 15, 2009 | Dometic Rooftop RV Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
66 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
