Question about Acer Aspire 5720-6661 Notebook PC
HTTP 400 BAD REQUEST
I get HTTP 400 bad request when ever I try to open facebook
Apparently I forgot my password when I try to reset it I get this messagd
How To Fix the 400 Bad Request Error
  1. Check for errors in the URL. The most common reason for a 400 Bad Request error is because the URL was typed wrong or the link that was clicked on points to a URL with a specific kind of mistake in it, like a syntax problem.
    Important: This is most likely the problem if you get a 400 Bad Request error. Specficially, check for extra, typically non-allowed, characters in the URL like a percentage character. While there are perfectly valid uses for something like a % character, you won't often find one in a standard URL.
  2. Clear your browser's cookies, especially if you're getting a Bad Request error with a Google service. Many sites report a 400 error when a cookie it's reading is corrupt or too old.
  3. Clear your DNS cache, which should fix the 400 Bad Request error if it's being caused by outdated DNS records that your computer is storing. Do this in Windows by executingipconfig /flushdns from a Command Prompt window.
    Important: This is not the same as clearing your browser's cache (next thing to try below).
  4. Clear your browser's cache. A cached, but corrupt copy of the web page you're trying to access, but are getting the 400 error on, could be the root of the problem. Clearing your cache is unlikely the fix for the majority of 400 bad Request issues, but it's quick and easy, and so worth trying.
  5. While this is not a common fix, try troubleshooting the problem as a 504 Gateway Timeoutissue instead, even though the problem is being reported as a 400 Bad Request.
    In some relatively rare situations, two servers may take too long to communicate (agateway timeout issue) but will incorrectly, or at least unhelpfully, report the problem to you as a 400 Bad Request.
  6. Contact the website directly that hosts the page. It's possible that the 400 Bad Request error actually isn't anything wrong on your end and it's something they need to fix, in which case letting them know about it would be very helpful.
May 28, 2015 | Computers & Internet
Hi im having a problem accessing my facebook as my laptop keeps saying the following info. HTTP error 400 your browser sent a malformed request, browser sent an invalid request, accepts requests complying...
Install java first from here: http://www.java.com/en/download/index.jsp
Next install Adobe flash player from here:
http://www.adobe.com/support/flashplayer/downloads.html
Click on get the latest version.
Accept Adobe dlm
confirm the licence agreement
Check your browser settings
select internet settings and advanced
click on redo advanced settings and click apply and OK.
You maybe have to restart your browser.
Clean up your browser while your are in there.
It does not do any harm.
Good luck.
Mar 09, 2011 | Facebook Social Network
I am at a hotel and I cannot connect to the internet. The message says bad request http 400
bad request http 400 simply means that the receiving host could not understand your request.
Look at: http://www.getnetgoing.com/HTTP-400.html for a series of errors that could cause it.
Dec 06, 2010 | Sylvania G-Netbook
Every time i go 2 youtube it says 400 bad request.
CauseThe 400 Bad Request error is an HTTP status code that means that the request you sent to the website server (i.e. a request to load a web page) was somehow malformed therefore the server was unable to understand or process the request. Resolution
  1. Check for errors in the URL. The most common reason for a 400 Bad Request error is because the URL was typed wrong or the link that was clicked on points to a URL with some kind of mistake in it.
  2. Though it's rare, the 400 Bad Request error could be an issue with the web site's server that you are trying to access. You may want to attempt to contact the webmaster or another site contact and inform them of the error message. The webmaster of most Internet sites can be reached via email at webmaster@website.com, replacing website.com with the actual website name.
Sep 01, 2009 | YouTube Videos
When using google alot of the sites I try and log into comes up 400 bad request. I can get into some sites but not facebook and some others. Looked up 400 bad request solutions on google but wont open....
This is web server error .The Web server (running the Web site) thinks that the data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) was 'malformed' i.e. did not respect the HTTP protocol completely. So the Web server was unable to understand the request and process it. It almost always means bad programming of the client system and/or the Web server. Trty to check after some time or reset IE setting to default, also try to disable firewall and check. Good Luck.
Aug 28, 2009 | Computers & Internet
400 bad request
Clear your browser cache (temporary internet files) & cookie And again try to load you tube.
If that doesn't work, use a different browser. E.g. Firefox, Google Chrome, Opera. NOT IE.
If that doesn't work, then use Proxy.
For an explanation about the "400 Bad Request" visit http://www.checkupdown.com/status/E400.html
Jul 01, 2009 | YouTube Videos
Facebook page won't load, says HTTP 400 Bad Request.or Failure to
I wonder if the site is experiencing technical difficulties...you might try to wait for a few hours to see if it is the website..sometimes webmasters bring site down to update site and clean up servers.
Apr 10, 2009 | Acer Computers & Internet
I cant enter hotmail it says http 400 Bad Request
hi.
Cause The 400 Bad Request error is an HTTP status code that means that the request you sent to the website server (i.e. a request to load a web page) was somehow malformed therefore the server was unable to understand or process the request.
Resolution
Nov 30, 2008 | Computers & Internet
Http 400 bad request
download latest expoyer 7 ok and update cam software and windows driver if any
Jan 24, 2008 | Sony SNC-RZ30N Network Camera
Acer Aspire 5720-6661 Notebook PC Logo
278 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
