Question about Sony Playstation 3 (PS3) Console
Hard disc i went online for the first time last night, and when i turned my ps3 on today, there is an error message  THE HARD DISC DATABASE WILL BE REBUILT. when I click ok, the ps3 turns off...can you assist me with this problem please?
  • 51 Answers
Re: hard disc
Try taking the harddrive out and put it back in or u may have to try a new hard drive
Posted on Nov 18, 2007
0 characters
3 Points
Playstation 3 says the hard disc file is corrupted
i have been scanning these answers for hours trying to find something that worked. i didnt want to buy another hard drive or enclosure to plug it into my pc so i tried this..... It worked first time, i just turned the system on waited for it to start getting into the loop then pulled the hard drive. it read error on the screen, the ps3 turned off. i turned it off at the power switch, plugged the hard drive back in and turned it back on and it worked first time, went straight to first time setup! im well pleased!
Jul 24, 2010 | Sony Playstation 3 (PS3) Console
PS3 Hard Drive Error or Restore Hard Drive
A Hard Drive error is a very common problem on the PS3 and this tip will outline how you can troubleshoot and hopefully resolve a hard drive problem. If your PS3 is showing signs that the hard drive is corrupted or is displaying a message asking you to restore the hard drive follow these steps carefully and you may well avoid an expensive repair or having to consign your hard drive to the bin.
Steps 8 and 9 involve erasing data from your Hard Drive so if at all possible please try to back up your data before commencing this procedure. To back up data go to 'System Settings - Backup Utility' Then follow the on screen instructions and back up the information to an external storage device such as a USB Pen.
To begin the process of troubleshooting and resolving your Hard Drive error you must first put the unit into Safe Mode. Follow these steps carefully;
1) Turn off the PS3 by holding the power button on the front of the unit till it turns red.
2) Hold the power button until you hear the unit beep three times. This will take 15 to 20 seconds.
3) The unit will power off on the third beep and power light will turn red again.
4) Touch and hold the power button again as in step 2. The unit will beep three times except this time the third beep will sound like a quick double beep. As soon as you hear this double beep release the power button.
5) You will see a message onscreen telling you to "Connect a controller using USB and then press the PS button".
6) Do as the message says i.e. connect the controller and press the PS button - you are now in Safe Mode and the hard drive repair can begin.
7) Restore File System. From this point select "Restore File System" on the menu. The PS3 will attempt to repair damaged files on the hard drive. If this does not work move to step 8.
8) Rebuild Database. Enter Safe mode again as outlined and this time select "Rebuild Database". Be aware this mode will erase some information from your hard drive which is not recoverable such as photo and message information. If this fails move to step 9.
9) Restore PS3 System. Again enter Safe Mode and select "Restore PS3 System". This will restore all defaults and completely formats the drive.
Be aware this mode will erase all information from the hard drive.
If everyone of these steps fail and the PS3 is still showing symptoms of hard drive error you can be certain that the hard drive has failed and it will need to be replaced. However in a majority of cases these steps will resolve the issue.
Many thanks for viewing this Tip and I hope it has been helpful to you.
on Dec 06, 2009 | Video Game Consoles
Yes my playstation 3 is saying hard disk needs to be rebuilt and it only says ok so i click ok another message pops up and says hard **** not found hard disk data will be deleted and lets you selesct ok or...
you could try to remove the hard drive then boot up, then put the hard drive back in and boot and see if that helps or you can try to rebuild the file system and database.
To get to ps3 recovery console to rebuild the database or the file system(neither will format the hard drive), when the ps3 is in standby mode(red light) press and hold the power button till you hear a double beep.
Most of the time the double beep comes after the ps3 beeps once then twice then turns red again when red again release and press again real fast and hold,... this time you will here a "beep" then " double beep beep" then you release and you will have the options to rebuild the database or the file system. basicly keep holding power button from standby till you here a double beep, if it shuts down try again, once you get the hang of it its easy.
if rebuild database and file system doesnt work then you may have to choose yes on the reformat option but it will wont hurt the ps3 itself just anything you have saved on it.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 not sucking in the disc
contact sony for repair the bluray drive needs replacing
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
Ps3 not reading disc
PS3 is The amazing device by sony but it has some common problems like unreadable disc, disc error etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
Start up problems
if there is any way that you can get to your ps3's main memory, either restore your system or open up your ps3 and find its memory and take it out and put it back in.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Its not reading the disks
Yeah this same thing happened to me, I had not played the PS3 in a while, my 2 sons 6 and 12 play it more than me!. Anyway one day I went to put a disc in, and low and behold it wouldn't read the disc!. Next thing I know I'm getting an error message saying "needs to rebuild database". It was unable to rebuild the database and instructed me to reformat the hard drive!, well I didn't reformat it, instead I turned off the system, unplugged all the cords and let it sit for 24 hours. When I hooked it back up, the error message disappeard and it was reading discs again! HURRAY!!!. What I'm going to do, and you might want to as well is, invest in and external USB hard drive. They sell them at Best Buy for around $100.00. The PS3 has a backup utility, but you need somewhere to back it up to. I'm not sure if any USB external hard drive will work, but you might want to check into it. Hope this helps.
Aug 25, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
61 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
