Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
SOURCE: need an owners manual for a john deere lawn LT-133
you can go to www.deere.com and then click on residential equipment on the next page click on services and support and then enter your model number you will need your machines serial number to choose which model you have. here you view on online or order a new copy on cd
SOURCE: Replacing traction drive belt for John Deere L118
Actually this is a fairly easy looking one to replace. If you go to John Deere parts and do a search for your tractor, in the parts listing it gives a pretty clear picture of the routing and configuration of the belt as it should go on, you might want to print it out to have nearby while you are working on it. You will need to remove the mowing deck to get at it and possibly some large blocks to elevate the tractor to give yourself room to work.
Look closely at the old belt if it is still on the tractor to get an idea what is involved BEFORE you start, comparing it with the picture. You will need to loosen and move or remove the belt guards and do be careful of the nylon fan on top of your transaxle
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317. They were made from 1979 to 1982.
You can only get manuals either through here: http://techpubs.deere.com/deere/Default.aspx or from a dealer. They're expensive. You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
SOURCE: need diagram to replace belt
See if this is even remotely close to your mower deck:
http://opebycrigby.tripod.com/decks/jd/jd48edgew.jpg
Also see if you can locate the mower deck model number i.e STX 38, STX 42 (Deck color Black or Yellow?) Should be a silver decal with black lettering. Also... there is supposed to be a belt routing diagram on the mower deck. (Another silver decal with the belt routing picture)
Kelly
