Question about Cycling
I/ve just changed the battery of my echo f7 cyclocomputer and wiped out the setting for the wheel size. What setting correspods to wheel sizes - 18'' wheel?
5 Suggested Answers
  • 4 Answers
SOURCE: Wheel size
2105mm should get you very close.
Posted on Sep 20, 2009
  • 13 Answers
SOURCE: I have a Huffy 13F WIRELESS COMPUTER for my bike,
go here:
http://www.huffybikes.com.au/index.php?module=product-detail&product=11
and contact Huffy. They can email you another manual
Posted on Oct 03, 2009
SOURCE: What must be setting on wheel size if my bike
get a tape measure and measure the out side circunfrance of the wheel. This is you number. OR put a white dob of paint on the tyre and roll it in a strainght line until the dob of paint makes a 2nd mark, (on a path way etc) measure the distance. this will be the same as the first option. Generally its required in mm.
Posted on Oct 26, 2009
dunnbiker
  • 8546 Answers
SOURCE: I'm trying to set up the correct wheel size for my
The manual explains how to measure your wheel exactly and set it into the computer...
http://www.sigmasport.com/en/service_center/produkt_support/bikecomputer/?flash=1&typ=bikecomputer
Page 28 and 30.
Posted on Feb 08, 2011
How to remove rear springs on Xtrail T31?
Removing these springs is extremely dangerous. You can rent a spring compressor at your local auto parts store. Be aware that changing that tire size also changes your speedometer reading and the handling of the over all truck as well. Shocks may not work properly either. Dig deep into all the things that change. Good Luck
May 26, 2014 | 2011 Nissan X-Trail 2.0
Size file sharpen poulan 18
Take your saw to a shop that repairs chainsaws. They will be able to get you the right file for the size of chain on your saw.
Dec 18, 2013 | Echo CS600P Gas Chainsaw 20 Inch
What size tyres camaro 1997 3800rs v6
The wheels could have been changed on the car from the standard original factory set and hence the tyre size may not be the standard factory original size.
The size of the tyres on the vehicle now is moulded into the side wall of the tyres and is easy to read.
Check all 4 tyres because larger size tyres may have been fitted as a pair to the rear.
The size might read - for example 245 45 18 or 235 45 17 (there are a huge number of sizes for each model of tyre).
The first 3 numbers are the width of the tyres in mm eg 225 mmm or 235 mm and so on. The second 2 numbers are the tyre profile size or ratio (which can be 70 65 60 55 50 45 40 and so on. The third number is the wheel diameter size. If you have 18 inch wheels on the car the tyres will read 18 or if they are 17 inch wheels the tyres will read 17 and so on.
Dec 20, 2012 | 1997 Chevrolet Camaro
I just bought a Bell Wireless Cyclocomputer (15 function) and I can't figure out how to set the tire size. Ive been holding down both buttons for different amounts of time and and I can't get it...
after holding down both buttons for 3 seconds those four numbers show up . They are changed according to the tire measurement. Use the chart in the manual to determine your four numbers. then set each digit by repeatedly pushing the set button. push the mode button to advance to the next digit. After the fourth digit is set the set mode will advance to the next setting.
Jun 10, 2011 | Cycling
I have a Hyundai, Genesis, 2010 coupe, 4 cyl. I have been having problems to establish what type and size of winter tire I should put on this vehicle for best performance both in snow and ice. I have...
HERE IS THE REAL QUESTION YOU SHOULD ASK OF THE DEALERS WHO ARE OFFERING 17" OR 18" TYRES FOR A TYRE SIZE THAT DOES NOT FIT YOUR EXISTING WHEELS......HAVE YOU GOT 17" OR 18"WHEELS???......225/45 ARE GOOD.
Nov 02, 2010 | Hyundai Genesis Coupe Cars & Trucks
I HAVE TWICE POSTED MY PROBLEM ALRAEDY IN THE LAST COUPLE OF HOURS,. i HAVE A N ECHO Wireless Computer W1 - in changing this between bikes I have somehow manges to lose the setting up instructions, I am...
Go back to where you bought it and see if they have an extra set of directions. If, they don't maybe they can call the manufacturer of Echo. Or you neighborhood bike shop mechanic may know the numbers for your wheel size.
Aug 22, 2010 | Cycling
How do I calculate wheel size for my bike. 25 inch wheel without tire for example
There's a size chart on page 15 of the manual that has great instructions for measuring and entering the wheel size.
You can get the manual from Sigma's website at this link.
Method "B" is the most accurate way -- make a chalk mark on the tire and stand the bike up next to a wall with the chalk mark at the bottom.
Have a friend make a chalk mark on the ground at that point.
WITH YOUR FULL WEIGHT ON THE BIKE, move forward for one rotation of the wheel -- until the chalk mark is on the bottom again. Do this as straight-line as you can.
Have your friend make another mark on the ground at this point, and measure the line between the two points on the ground.
This is the wheel circumference, and if you do this with normal tire inflation and with your full weight on the bike, it's the most accurate way to calibrate your cyclocomputer.
If this helps, please be sure to hit the "thumbs up" for me.
If not, of if you have questions, use "add comment" to post back here, and I'll do my best to get you going.
May 20, 2010 | Sigma Sport BC1106 Dts Wireless Bike...
Cycling Logo
1,623 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
