Question about GE Dishwashers
Dishwasher does'nt drain in all cycles drain line is clear
  • 51 Answers
If it is not the drain line, this could also be a vlave or if you have a new garbage disposal you have to punch out a peice of the plastic on it before it will drain.
Posted on Jul 15, 2009
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
Apr 05, 2014 | Whirlpool Dishwashers
Dishwasher has about 2" of
Is your drain line clear? It feeds into your sink drain and if there is any blockage it can prevent a good drain. Is the drain line as straight as possible? Make sure the bottom of the dishwasher is free of debris (food, paper from labels, etc; plastic pieces) . To be safe you can take a long handles brush and scrub around the center of the drain area to dislodge any materials. Also, a white vinegar rinse will sometimes help remove debris and clean the interior of the washer. 1/2 cup white vinegar in the tub and then begin the cycle. If none of these remedies help, it might be the pump or the timer.
Oct 28, 2010 | Vacuums
Water left in the bottom of dishwasher after cycle was complete
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Aug 27, 2009 | Frigidaire Dishwashers
Whirlpool quiet iv runs for 10 minutes on 72 minutes and 42 minut
make sure the drain line is clear ....when the dishwasher is going through the drain cycle there should be water running down your sink drain .....if you don't hear it or see it then your drain line is pluged ....un plug it and you should be fine
Jul 24, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water leaking from dishwasher lg model lds5811ww
The drain line is clean. Have you checked to make sure the the rest of the drain is clear all the way down to the main drain?. Also check the pump to make sure that it is working properly, it might be pumping water in, but it may not be wanting to pump the water out
Feb 11, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Water drains thru the vent
If water flows from the vent, it indicates some type of blockage in the drain line downstream of that point. You can rent something called a "Drain Snake", which will require you to take apart the drain line to clear the obstruction, or you make purchase some liquid drain cleaner and see if that will clear the problem.
Hope this helps,
Kermit
Aug 23, 2008 | Magic Chef 24 in. DU2000 Built-in...
Standing Water in Dishwaaser
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 15, 2007 | GE 24 in. GSD4060JSS Built-in Dishwasher
Dishwasher does not complete cycle
It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 09, 2007 | Miele 24 in. G638 Plus Free-standing...
Dishwasher won't drain
Aug 16, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Apr 14, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
49 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
