RCA DWA1015D - Digital Stream 10-Inch Droid Tablet Logo
My tablet is stuck
It on the first page and can,t get it to move
My tablet when turned on it gets stuck in android and doesn't want continue. I had searched and I need the rom update but I don't find it
This is likely something you need to get from the support page for your device; you should contact the manufacturer if you have trouble with this.
My tablet when turned on it gets stuck in android and doesn't want continue. I had searched and I need the rom update and I Don't find it
This is a duplicate of this post: My tablet when turned on it gets stuck in android and doesn want continue...
The same answer applies. Contact the manufacturer or check their support page.
1helpful
My vizio tablet is stuck on opening page and wont swipe open
Hi Beccajune,
looks like your touch pad does not working.
please go for the repair maybe its a little loose contact with flex cable and connecting port in the inside.
regards,
nuwan.
1helpful
Frozen screen
Force it to shut down by pressing the power button down for 10 seconds, then release and turn on again.
Telefunken tablet tab700
how do i reset my pattern i forgot it so my tablet is locked
Stuck on visual land jelly been page and won't reset
Try to perform a hard reset. The most common way to factory reset an android device is these method. 1. turn off your device 2. Press the your Volume up button and power button at the same time for a period of time 3. you will see the android image appear on the screen after that you will see some options 4. Choose the WIPE DATA/FACTORY RESET by moving your selection using the Volume buttons 5. Select it using the Power Button Then wait for it to finish the resetting process.
Top RCA Tablets & eReaders Experts
 Mikey
Mikey
k24674
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
