Question about Canon LaserClass 2060P Plain Paper Fax
I need to verify a received fax, but the connection tel column is blank (there is no number shown). How do I see who sent the fax at that time. There is a transaction number.. but how do I match this with the sent number. -
  • Canon Master
  • 5,568 Answers
It's possible that the originator has their number blocked (caller ID blocking). If that line is only used for the fax, I would try to learn the number using that same line and then using a phone, dialing *69 (in our area, yours may be different). If your service operates the same, you should get a voice message with the number and an offer to dial it for you.
Posted on Jul 15, 2009
Can not receive or send fax. There is the phone tone on the BT line.
When we are speaking about faxes you have to try at least a few numbers, because there is sometimes a temporary problems with tel line speed. To send or receive the fax the tel line should be stable. Fax machine try to connect to highest speed (33,6 by default) and if the line is not stable you will receive connection error.
Try again but tomorrow or ask yout telephone company if there is a problem with line
pifonski
Feb 20, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Somehow our machine is no longer on auto receive. we need to pick up the receiver and hit start each time it rings in order to receive the fax please help
Press the Reception Mode button to toggle between Fax, Answering Machine and Tel (manual receive). If you need to change the number of rings before the Fax is picked up, press Function 4 then # # # Then press a number between 1 and 5 followed by Stop.
I hope this helps.
(BTW there is a little arrow that points to the Reception Mode on the LCD screen -> Tel on the left, Fax on the right (both of these across the top right), and A.M. on right side.)
Aug 06, 2010 | Sharp FO 2950M Plain Paper Laser Fax
Confirmation page shows zero pages sent. Is there a way to set to show the number of pages sent
I would first test a fax to see if it completes on your end then is received on it's entirety on the receiving end. Then print a fax transmittal report to confirm. Once that shows success, print your polling fax report and verify.
If it says zero pages sent, chances are the fax failed.
Jan 14, 2010 | Brother IntelliFAX 4100e All-In-One Laser...
I print a activity report and the connection tel. is blank how come it is blank and does not show phone number
If the fax machine you send the faxes to is set not to show the ID (telephone number) it will not show the tellephone number in the activity report.If you use a telephone conected to the fax and you dail a number from the handset it will aslo not display a id on the activity report.
Dec 07, 2009 | Canon FaxPhone L75 Plain Paper Laser
Panafax 585 block fax reception?
Press
Function
64
set
look at your settings again
Fax number 1 set to tel
Fax number 2 set to fax / tel
Feb 18, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Can not send a fax
Plug a regular phone into the wall jack to verify a dial tone. Make sure the phone line is plugged into the LINE port of the fax.
Oct 02, 2008 | Canon FAXPHONE L80 Laser
Brother IntelliFAX 4100 shooting out blank sheets
The machine told you poor line quality. Try a different phone line to verify. Try it at a friends house to verify it. If you are using Vonage, that is the problem. I have Vonage and every fax I test with has some issues with poor line.
Aug 07, 2008 | Brother IntelliFAX 4100 Laser Fax
Sharp fax machine: help!
look to see if it is in tel,fax,or a.m. mode you need to have it in fax mode.tel=telephone,a.m.=ansering machine
May 09, 2008 | Sharp FO 3150 Plain Paper Laser Fax
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Brother Intellifax 1270
There is a help menu on this machine. To print this out, just press the help button. To change the fax/tel ring, 1st have in mind how you want your fax machine to work. Do you have an a TAD connected? Do you want the fax machine to take priority over tel calls? The fax machine seizes the line after the set number of rings, that means any other device connected to other phone outlets, will not answer after the fax has answered. Have this in mind when you set the ring time. The TAD will have it's own ring time too.
Feb 29, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Canon LaserClass 2060P Plain Paper Fax Logo
80 people viewed this question
old marine
old marine
