Question about Toshiba PA2611U External Floppy Drive
External drive shuts down the Toshiba 460CDX/2.1. OS is 2000. I do not have Admin rights to add Hardware, the Admin is no longer available. The CD writes does not write to a CD only plays CD's. I need to get data off this machine. USB floppy is not recognized. The external floppy use to work, but a 3.5 disk got stuck in it and I removed it, now the external shuts down the laptop when it is attached. Do you think it is the floppy or the port that is damaged? The external floppy is a PA2611U and I'm having difficulty finding this. I just odered one and was sent PA26611U, which does fit.
    Scholar:
  • 71 Answers
The external cd drive should be having both CD and DVD options, that is Combo Drive or Super CD Drive where you can write all your data on to the DVD - eitherway it can be done. You can copy the data from DVD / CD on to your toshiba laptop.
Best solution is replace the exisitng laptop to a latet one with Vista option. Will solve your probllm. Otherise try to contact the local authrozed hardware engineer to assist you in solving this problem.
Good Luck.
Posted on Jul 16, 2009
How to get driver for cd dvd unit
The optical disc drivers are part of the OS. The available drivers and software for Windows Vista, the original OS for the DV6748us are here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&product=3648284 . Select your version and click Next.
Windows XP and the subsequent versions of Windows all had the drivers for internal optical drives and most external drives in the Plug and Play control. You may need to go to the Device Manager and check the device status then manually update the driver. (For Vista, click Start > Control Panel (in the right hand column, then under Hardware look for the Device Manager link.) Expand the section for optical drives and look for a triangle with a red x or a yellow exclamation point. Right click on the device and click on the Update Driver button. If that doesn't work, try uninstalling the driver then shut down the computer. Check if Windows loads the driver correctly when you reboot. If you continue to have problems, the drive or cables might be bad. Consider getting a new optical drive (slim if you want to stay with an internal drive).
I hope this helps.
May 08, 2014 | HP Pavilion dv6748us Notebook
My notebook Lenovo no longer reads Toshiba HDDR320E04XW 320 GB USB Hard Drive which earlier functioned correctly.
1. Try to plug in the external hard drive.
2. Goto device manager
2.1. Click Start -> (Right Click on My Computer -> Left Click on Properties-> Click on the Hardware Tab -> Click on Device Manager on Windows XP
2.2 Type "Device Manager" on Start Search (Windows Vista)
2.3 Type "Device Manager" on Search Programs and Files (Windows 7)
3. Click on the Triangle next to Universal Bus Controller
roadfox.png 4. Look for a USB driver says "Unknown" Uninstall it and restart the computer with the external hard drive plugged in and you are all set
Thank you for Choosing
Jul 07, 2011 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
Having just reinstall my OS (XP and rebuilt my PC, my MicroSolutions Backpack external hard drive (model 155010) no longer works. I installed the drivers off the original CD but to no avail. Is there an...
1. See whether Chipset drivers have been installed.
2. Try replacing the USB Cable.
3. Check whether this HDD is detected in another system.(If it detects and works fine then get your system checked for USB port, else you external HDD is having problem.)
Sep 05, 2010 | Micro Solutions Backpack (502008) 250 GB...
Driver missing for cd dvd drive
1st, do you have access to internet ? I'm assuming you don't have a utilities disc for your computer, and that it's a pc, not a mac.Go to control panel; add hardware;cd drive or dvd drive see if model is listed.(You may right click on computer;properties in order to find model).If it is listed, click update drivers...usually you will be asked if you have a disc, of which you don't...then you may get 2 options; choose from a list or for windows to check web for available drivers.
(Most cd/dvd drives work well with windows generic drivers)
Mar 07, 2010 | Computers & Internet
Toshiba NB 100 fatal screen
this is a case of os corruption somehow..!!..may b a virus/trojan or hardware or software is responsible..
all u need is the os boot cd anyway..
reinstall os..
(totake data backups u gotta connect the hdd to another pc/laptop, for suchcases a hdd-case is available in the local spare market, it'll makebehave ur hdd to act as an external removable drive)..
this canalso b a symptom of faulty/defective of RAM..pen clean/remove carbon& or oxide formed on the teeth with an eraser n resit it..[it'll bmore prominent, that if itz cause by ram or not,..if during normaloperation, a Blue Screen appears/Memory Dump]
though, sometimes itz also caused by the m/b..
see if ur hdd is making any humming/ticking noise (like 'tuc tuc' or 'kirr kirr')..if so it is likely to be replaced..
if once u can login, do the following:
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, , without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all theunnecessary startup items from here..(if u can't find what toremove,post me/us in ur comment with all the items listed in each nevery tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disable thefollowing: a) 'Automatically Restart' right click onmy computer->properties->advanced->startup nrecovery->(uncheck on the) Automatically Restart; b)'ErrorReporting' right click onmy computer->properties->advanced->errorreporting->disable error reporting->(uncheck on the) 'but notify mewhen critical error occur'..
Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
always better to seek professional advice of ur system admin/vendor....
Nov 10, 2009 | Computers & Internet
Toshiba tecra will not boot up
Your motherboard is the issue here I have seen this problem many times but just to make sure try hooking it to an external monitor
Dec 08, 2008 | Toshiba Tecra 8200 Notebook
Boot problems
hi friend
Keep pressing F2 or del soon as you start up your PC u have to go in cmos setup by perssing f2 or del key when windows stat then press it there was option in go in boot there is boot device pryority set there cd dvd rom by press f10 to save cmos settings & exit then after pc was reboot u will able to boot from cd
Apr 11, 2008 | Toshiba QOSMIO F15-AV201 Notebook
CD's in drive do not load
Buy a CD/DVD cleaning disc. Try that. Maybe the read head is dirty.
Aug 29, 2007 | Toshiba (PA3352U2CD2) CD-RW/DVD-ROM...
Restoration disks
You should'nt have a problem installing as long as you format the hardrive first, as windows can only id the hardware profiles once installed, but you may not be able to do this if it's only a restore disc. This hardware recognition process can be sorted easily if required to validate windows by going on line when installed and microsoft will read the o/s product code automatically and validate.
Jan 30, 2007 | Toshiba Satelite 5205-S505 Notebook
Toshiba PA2611U External Floppy Drive Logo
166 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
