Try this at your own risk.
Step
Consider using a product made for
stainless steel such as Scratch-B-Gone or Bar Keepers Friend (see Tips).
Step 2
Or, try spraying an all-purpose cleaner (such as Formula 409) on the scratches.
Step 3
Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
Step 4
Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
Step 5
Rinse the surface and wipe dry.
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
Tips & Warnings
Before using any treatment on your stainless cookware, sink or appliances, it is wise to call the manufacturer for advice.
A new product called Scratch-B-Gone is touted as the "first aid kit for stainless steel." You can find it at many home improvement stores.
Bar Keepers Friend is another product for stainless steel. It can be found in most grocery or home improvement stores, or at www.barkeepersfriend.com.
To keep stainless steel sinks from scratching, put a rubber mat in the bottom of the sink to protect it.
Avoid using abrasive
Please rate 4 thumbs for the free answer
