Question about GE Washing Machines
I have a Top Load GE Model #WBSR3140G1WW. The
I have a Top Load GE Model #WBSR3140G1WW. The spin cycle is not working. The water drains but it doesn't spin and it is not dispensing the fabric softener. The motor is running but nothing is happening. Normally when it is in the spin cycle I can't raise the lid. Now when it is supposed to be spinning, I can raise the lid.
Last Saturday (7/11) we had a storm and lightening hit and got our TV converter box, direct tv receiver box, dvd player, the GFI outlet in the bathroom and another outlet on the outside of our garage. We also lost power to the bathroom lights, the computer and lights in that area and the light in the laundry room. I flipped the circuit breakers off then back on in those areas and the lights and computer came back on. I don't know if lightening got the washer or it's just a coincidence that it started having trouble now. Dryer is working fine. Any help would be greatly appreciated.
    President:
  • 512 Answers
This is an electronic washer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly. This will reset electronic motor.
Posted on Jul 18, 2009
When the washer gets to the spin cycle it seems to stop and not pump out the water. All other cycles seem to work ok. It is a GE spacemaster 22"
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | GE Spacemaker WSLP1100D Top Load Washer
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Water is not draining?
heatman101
May 31, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
Water in clothes after spin cycle
need to open washer and check the DRAIN MOTOR PUMP , usually gets clogged with lint and debris , usually located at the bottom side , small motor w/ propeller ,where the drain hose is connected, AJ
Nov 11, 2009 | GE WJRR4170E Top Load Washer
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Wobbels and vey loud during spin cycle
hi there,
looks like you have an unbalanced load of clothes. this usually means that your drum is out of alignment, hence it makes a lot of noise. i would recommend having a technician come out and it's a big job to have it put back together. you may have to replace the coupling or brake as well. have him check if anything is actually broken.
thanks
Sep 27, 2008 | GE WBSR3140DW Top Load Washer
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
GE Washer top-load WLDSR416FOWC
Actually, I think I do remember having one do this before, and I believe on these GE models the spin cycle goes through the water level switch, so if your water level switch is sticking, then it won't spin, thinking its still full of water.
Here's the water level pressure switch for your model:
Manufacturer part#WH12X10065 is RepairClinic item#2205
don't forget to rate me in main page,it is the only way i get paid for my works..
Jul 23, 2008 | GE WDSR2080D Top Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
742 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
