Question about Frigidaire Dryers
Error code e-68 won't clear the message. Dryer stops working
  • 744 Answers
Hi..
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.
thank u
rate me!!
Posted on Jul 15, 2009
What is an error code e-68 on a galaxy series dryer mean
E68 error code is a stuck button error code. You can try to wiggle each button on the control panel to make sure they are all functioning freely. If so, then unplug the dryer and leave it unplugged a couple minutes then plug the dryer back in to clear the electronic panel's error code. If the panel still shoes E68, then you'll need to replace the panel. Part#134557201
Hope this helps!!
Jun 13, 2016 | Dryers
I HAVE A EURODESIGN DRYER BOUGHT IN '03 I now have error 68 message and dryer stops - anybody know what this means - cant find it in the manual. thanks
It means it has a stuck button.
I'm taking it that it's a Fridgidaire.
on the door you should have a model number that looks like this
AEQ6700FS .
http://www.searspartsdirect.com/dryer-repair/error-codes/frigidaire-dryer-error-codes.html
Once you find this and you need a manual goto
Browse Products
Apr 17, 2015 | Dryers
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
Frigidaire affinity error code 68
what is the name and model of these dryer.rate these for clean solution
thanks
Jan 16, 2013 | Dryers
My GE Profile Gas Dryer DPGT750GC1PL is giving me a message to contact a technician. I discovered a bird's nest in the outside vent which had it totally clogged, so cleared that, then cleaned out the...
typically the code and be cleared(if you havent already done this) is to unplug the dryer for 5 minutes and plug back in and temporary memory such as error codes are cleared. IF a problem persist after clearing the error code will return.
Gene
Aug 05, 2011 | GE Profile Harmony DPGT750EC Electric...
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
My electric dryer tell me ERROR 68 on the screen ¡¡ Plus every 5 minuts stop for she self ¡
The data sheet says "One of the buttons is stuck closed". If you can't solve this by inspecting & jiggling the buttons, open the lower front panel of the machine, & look behind it for the "Tech Data Sheet*. Follow the instructions for error 68.
Nov 27, 2009 | Frigidaire FEQ1442ES Electric Dryer
ERROR CODE 68 WILL NOT CANCEL. IF YOU PRESS CANCEL AND THEN START IT RUNS FOR ABOUT A MINUTE AND STOPS
code 68 [aeq7000es series]relates to "stuck buttons, or control panel issues. Try to see if your dryer will give you the code for which button is stuck and try to wiggle it to free it up if stuck. If all buttons check out good then you most likely have a bad control panel ,and its time to find your best deal on one
Sep 29, 2009 | Frigidaire AEQ7000ES Dryer
Fridgidaire Error 68 (model No. LE02152EEO) and constant beeping!
this fault code means there is a stuck key on the control board.you need to disassemble the display panel and free up the stuck key if this does not work then the display panel and or control board need to be replaced
Sep 02, 2009 | Frigidaire AEQ6000ES Electric Dryer
Dryers Logo
440 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
