A good place to start is 2 and a half turns out and play about from there.
Screw the adjuster all the way in to a soft seating. DO NOT force it, just screw it gently until it seats itself gently otherwise you will damage the seat or screw face. Now start unscrewing it counting the turns. I count quarter turns and 10 quarters is 2 and a half.
Fire up the bike and let it warm up and idle. Turn the screw in a quarter and see if it runs better, if it does then this is your base point. If it runs worse, screw it back out a quarter to the original starting point and then screw it out a further quarter. If this is better then that becomes your base point. Basically the base point is the best current setting that you know of. Start working from this base point adjusting and noting the changes until you get the smoothest running. Always write down your settings as you alter them and you will remember where you are. Remember you can always start over again, just don't damage the seating.
