Question about Microsoft HP Pavilion DV6276US Notebook PC
The wireless switch on my HP pavillion dv7-1130us is stuck (in off position). How do I "unstick" it? I've tried almost everything.
  • Microsoft Master
  • 5,660 Answers
1.If the switch slider is stuck from sliding by the laptop's case somehow, you open the laptop, and free it. Then see what transpired making this happen.
2.Upon opening the laptop, and finding that the switch itself is broken, (Mechanism inside the switch has broken), you remove the switch by unsoldering it, and then replace it.
3.You take it to a qualified computer repair shop, and have them do it.
My money is on the switch mechanism has broken inside the switch, and needs replacing.
If you need the Maintenance and Service Guide, in order to open the laptop to service this switch, here it is,
(It states -> Guide <-, but it is really a comprehensive manual, with printed instructions and illustrations. It's free, and comes directly from HP.com)
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3795407&
On this page scroll down to ->
HP Pavilion dv7 Entertainment PC - Maintenance and Service Guide <-, and click on it. (It's in Blue)
This is a PDF file download. You have Adobe Reader on your computer which uses PDF files.
After you click on the above, you may not see anything happening for up to 30 seconds. Be patient as it is downloading to your computer. You may see the first page after 10 seconds.
I advise waiting until it has Fully downloaded, before looking through it. You may break the download connection if you don't.
Should you wish to save this PDF file to your computer, (So you can view it anytime you want without having to wait for a download, and also so you can burn a copy off to a CD disk), go to the top header, and click on the Floppy Disk icon.
The Floppy Disk icon is the second icon from the left. Hovering your mouse cursor on it will briefly reveal, "Click to save this file to your computer or another location".
If you don't have your downloads set to go to your My Documents folder, (Start>My Documents), this file will go to your desktop screen. Just double-click on it to open it.
Posted on Jul 15, 2009
  • joecoolvette
    joecoolvette Jul 15, 2009
    Forgot to add.
    1.Before you open the laptop make sure the AC adapter, (Charger), isn't connected, and the battery is removed.
    2.Buy and wear an ESD, (ElectroStatic Discharge), wrist strap. These are cheap. Make sure the alligator clip is clipped to a good ground. (Example of ESD wrist strap:http://www.radioshack.com/product/index....
    3.Use a holder for the various screws that you will remove. I use a clean egg carton, and label each egg holder for the screws. I label the egg holder for each area. There may be 10 different sizes and threads, plus all the area they come out of. (LED cover strip, keyboard, top case, screw from out of the bottom case, and so on)
    4.You may want to use a digital camera, plus make notes and drawings for your first time in doing this. Make a record as you disassemble. Makes it easier when it's reassembly time.
My wlan switch stuck in the off position. if you pry off the cheap plastic switch,you will find 2 tiny prongs.1 of mine had broken. it was easy,and much simpler than any of the above ideas,to use a pin to move the switch to the on position. i just leave it there. if you really want to turn it off, click on the wlan icon and turn it off with the software link. its crazy to take the case apart for this
Posted on Jun 19, 2010
Hp pavillion dv6-2155dx keeps buffering and won't play videos correctly
Are you connecting wireless or wired connection. Have you updated your flash player? Which browser are you using? Do you keep your computer cleaned up from internet browsing? If your browser is up to date and so it your flash player then more than likely it could be the internet connection. If you are running it wireless try plugging it in to the router with a cable and check it. Another thing would be to check for a virus.
Jan 31, 2012 | HP Computers & Internet
Wireless capability shut off. what function key combo do I press to restore? It's a HP G50 Notebook
There is wireless switch - either under the screen or on the front of the computer. Find it and check position of the switch. Usually, there is light next to it. Good luck!
Mar 29, 2011 | HP Pavillion G50-111NR Notebook
I need an internal pin out diagram for a 4 Pin connector to connect power supply to a hp pavillion f70 monitor. I do have a power supply with same specs but it has a normal plug with outer as +ve and Inner...
12 VDC , 4.16 A (4,16 A) Frequency: 50/60 Hz Power Consumption: less than 36 W in operating mode.
I think the other two pins are not used. It just requires the 12 Volts DC. +ve and -ve, positive and negative, respectively.
Feb 10, 2011 | HP Pavilion F70 17" Flat Panel LCD Monitor
Not sure if this is the right model but it is an hp laptop. My cursor is stuck in the middle of the screen and the keyboard is non responsive. Everything loads properly but the cursor remains stuck in...
try to connect external keyboard/mouse. if that work, your input devices went south. did you spill something over? number of model is located at the bottom.
Nov 03, 2010 | HP Pavilion dv4000 Notebook
Where is switch for HP Pavillion laptop wireless
it must be in front of your laptop, try to look closely this is a sliding switch
Jan 08, 2010 | HP Pavilion dv4275nr PC Notebook
None of my quick touch buttons work. HP Pavillion dv9000
My thoughts is that you may have had a Microsoft update to which has knocked out your drivers for these features. You may have to go back to HP's Web site and re-load the drivers for these two features.
Blessings,
A/V Media Guy
Nov 19, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
No sound on my palm centro
There is a switch inside of the jack that sometimes can get stuck you have a few things you can try.
- Try to insert the jack and remove it slowly, the sometimes unsticks the switch.
- Try using a small bit of WD40 on a paperclip or similar small item in the jack to lubricate/unstick the switch.
If neither of those work there is an application you can download called headcold that lets you override the switch. http://headcold.sourceforge.net/
Aug 18, 2009 | Sprint Centro Smartphone
HP Pavillion wireless won't work
First, look thru HP Health check and download all recommended.
Second, go to HP site, download and reinstall WLAN driver and HP Wireless assistant software
Third, download at the same site HP WinFlash BIOS Update and update BIOS (READ and FOLLOW INSTRUCTIONS VERY CAREFULLY)
Reboot.
If you are lucky ;-)  WLAN will now works - try to switch it on by WLAN switch.
WBR, Planet
Jul 18, 2009 | HP Pavilion tx1000z Notebook
My hp dv7-1025nr wireless switch does not work.internal wireless card not responding.not seeing avalible wireless connections.
Hi...
This is a hardware issue the the switch need to be replace.
If the computer is in warranty contact HP.
Thanks
Smith
Dec 20, 2008 | HP Pavilion Laptop dv7-1025nr
Microsoft HP Pavilion DV6276US Notebook PC Logo
1,622 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
