Question about Garden
Lawn Mower Doesn't Stay Running
I have a Briggs & Straton 4.75 horsepower mulching lawn mower (branded Weed Eater Q4.75) and it suddenly stop running. I was in the middle of mowing when the mower just stopped. Have used the mower about a half dozen times this season with no issue. I could get it to run for about 10 seconds by priming and pulling the cord, but it was a bit 'chuggy' and then would stall. The oil level was almost non-existant and what was there was fairly 'sludgy.'
I have since replaced the muffler, left off the air filter and added oil. The air filter was dirty around the vent holes, but not horrible. I removed the spark plug to find it blackened and burnt looking so I replaced it. I have also pulled all the gas in the tank and replaced it with fresh just in case it was stale though I was fairly certain it wasn't.
At this point it will run for about 20-30 seconds but is still 'chuggy.' If I press the prime bulb while it is chugging along it will continue running, but it is fairly rough. I have pulled the new spark plug and see a very slight amount of oil on the plug - almost not noticeable unless you really look closely.
The big question at this point: Is it worth more time and money to keep trying to get this working or is it likely the mower is fried? Since the oil was almost gone and what little it had was sludgy I wonder if I killed the engine due to poor maintenance. I am fairly handy but don't want to rebuild the engine. I am open to try other things though as I would like to keep this mower running if possible.
Thanks in adavnce for your help,
Chris
  • CLEONTI
    CLEONTI Jul 16, 2009
    Hi Baboono - I tried what you noted and it didn't make much a difference. The carb doesn't look easily removed and I didn't see a float bowl either. I did find that if I crank up the throttle a bit the mower will stay running. For the moment I have just jury rigged something to keep the throttle about 25% higher than the default and the mower is usable. It seems the mower is running fine just not able to run at the default throttle any longer. It is strange that this literally occured in the middle of mowing the lawn but it could be a coincidence with the low oil situation. Does this new wrinkle change your thoughts about a solution? Thanks for the help, Chris
    President:
  • 1,129 Answers
Try this, while the motor is running rev it up as high as it will go if possible with air cleaner off then cover the carb hole with your hand, this will stall the mower be patient and do this over and over 5 times this should pull out any debree blocking the gas flow if this doesn't rectify the problem remove the float bowl if equiped and clean the bowls chamber replace , if it is the type of carb without float bowl remove the tank and carb disassemble clean reassemble and start/run.
Posted on Jul 15, 2009
HOW TO ADJUST DRIVE CHAIN ON WEED EATER ONE
There is a tension adjustment on the body.. flip your mower over and you can see it better.. do not over-tighten it though because it needs slack to let the 1-2-3 to change on the fly.
Aug 18, 2014 | Weed Eater WE-ONE 26-Inch 190cc Briggs &...
What could be wrong with my briggs and straton 271470 I already replaced the carb and governor but still stals out when the engine gets hot?
Check the coil,sometimes they run till hot then shut down when going bad after engine gets hot, also check to make sure for continuous gas flow unobstructed by dirty filter or water or trash in fuel.
May 04, 2014 | Mtd Yard Machines 158cc Briggs and...
Weedeater we261 riding lawn mower
Check your drive belt on the bottom of the engine.. that is what drives the machine forward.. if it has slipped off or broken, it will not go.
Apr 27, 2013 | Weed Eater WE-ONE 26-Inch 190cc Briggs &...
Problem with new briggs and straton mower, dust and a lot of it coming out rear discharge area towards motor
Seems you have a rear bag mower. 2 things: first get the proper bag for that model. 2nd- the door panels have seals which do wear out and are replaceable at your local mower shop or you can buy the parts and do it yourself with a few very basic tools.
Jul 02, 2012 | Briggs & Stratton Garden
I have weed eater/poulan 22" push lawn mower. It
Hi goldengear...
Make sure you have installed the blade on the right way, if it is installed upside down then it will "beat" the grass instead of cutting it and make a terrible cut, also make sure the blade is good and sharp.
The rough running may be due to trash in your carburetor, I would advise to clean your carburetor and also check you fuel tank for trash, water,etc. if there is any trash,water,etc in there then you need to also clean the fuel tank.
Do one more thing and check/clean/replace your fuel filter if you have one.
Please take time to rate me
Aug 18, 2011 | Poulan "Poulan" Push Mower
I just bought this lawn mover and recoil starter does not pull up?
You have to squeeze the safety lever on the handle to disengage the blade brake. This lever is meant to be squeezed while you operate the mower and will stop the mower instantly (well, pretty darn quick) if you release it while the mower is running.
Jul 06, 2011 | Mtd Yard Machines 158cc Briggs and...
Weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Jun 13, 2011 | Mtd 22" Yard Machine Push Mower
Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Aug 09, 2009 | Garden
Garden Logo
599 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
