Question about Husqvarna 160 CC Honda OHC Engine 21 in
Brand new Husqvarna R53SV 53cm Petrol Mower wont start. We put petrol and oil in it. Connected the spark plug put the choke to on, Pulled the starter string. Nothing happend. After trying a few times you can smell the fuel. Tried a different spark plug but still not starting. Any ideas. Thanks
  • 1 more comment
  • deakin_speak Jul 15, 2009
    great it might have too much oil in. Is there a drain plug for the oil or will i have to tip the mower on its side? I think this could be problem as my dad said he thinks he put too much oil in
  • Anonymous Mar 30, 2014
    Husqvarna R53sv
    President:
  • 1,129 Answers
Buy some starting fluid and spray some in the carb or air cleaner intake port, if the machine is flooding do not choke while using the starting fluid, make sure you do not have too much oil in the mowwer.
Posted on Jul 15, 2009
Our victa lawn mower is a 2 stroke and someone has put unleaded petrol in it, now it doesn't run, how can I fix it?
Try flushing the diesel out of the system with 2stroke fuel, replace the spark plug and try restarting!
Dec 30, 2014 | Garden
I have a gardentec 52cc chainsaw which wont start. I have a spark and fuel getting thro.
Hi you mentioned that you defo getting spark is that from spark plug against side of engine, try this put a very small amount 50/50 pet oil inside cylinder head through sparky entrance screw spark plug back in try it now if it pops abit no matter after 5 times you have a carb prob float faulty jets blocked, blocked feed line, Advise you need a bowl petrol no smoking wash carb in it blow clean jets put back only when all is clean check petrol tube sometimes they go hard and block up make sure petrol is getting to cylinder head, hopes this helps
Feb 17, 2014 | Garden
My mower started making smoke and then stop working?
SOUNDS LIKE THE OIL HAS FLODDED THE SPARK PLUG. REMOVE THE SPARK PLUG AND CLEAN IT USEING A WIRE BRUSH AND SOME BREAK PARTS CLEANER. THEN DROP SOME OF THE OIL OUT. YOU MAY HAVE PUT TOO MUCH IN THE ENGINE. THE SMOKING WAS CAUSED BY THE OIL BEEING BURNED BY THE SPARK PLUG. SOME HOW OIL GOT IN THERE. TRY CLEANING THE INSIDE OF THE SPARK PLUG OPENING WITH SOME CARB CLEANER. PUT THE SPARK PLUG BACK IN AND TRY TO START IT. REMEMBER IF THE SPARK PLUG IS FOULED UP, IT WILL RUN POORLY OR NOT AT ALL.
Jul 25, 2012 | Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Husqvarna R53SV Petrol Mower wont start. I think too much oil had been put in. I drained some out bu still wont start. Is the engine flooded? how could i start it? Thanks
Use starting fluid when it does finally start continue starting until all the oil is cleared out of the carburator you may need to repeatedly choke out the carb with the engine running to clear out the carb, do this by removing the air cleaner, start the mower on high speed rpm, and cover the air intake with your hand repeating this start/ choke/ stall procedure until it is cleared out it works, I just did this to a mower last week that had too much oil in it, the mower smoked quite a bit but eventually returned to normal
Jul 15, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Nannie what can be wrong with my power devil petrol lawn mower the engine wont keep running then cuts out petrol and oil ok
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Jun 23, 2009 | Mtd 22" Yard Machine Push Mower
Brand new Pope Spitfire 40 lawnmower won't start
Caren,
Drain the fuel completely if it is older than 1 week. Make sure you undo the bolt at the bottom of the fuel bowl to ensure all old fuel is drained. Refill with fresh fuel (premium unleaded) and try again. If it still does not work then remove the spark plug and rest it on the metal of the mower while still attached to the silicone ignition wire. Have someone hold the cut out bar to the handle (as you normally would to run the motor) and pull the cord. You should see sparks being emitted from the spark plug. (Make sure there is no fuel nearby) If you cannot see any sparks then replace the spark plug with a new one and repeat this process. If you still cannot see any sparks being emitted after attatching the new plug to the silicone wire, resting it on the metal of the mower, and pulling the cord to start it as you normally would, the mower will need to have the resistor and capacitor checked by a professional repairer as no spark is being generated.
Good luck.
Allan
Jun 06, 2009 | Garden
Can not start mower - petrol n oil ok - how do I get into s plugs
Fuel in the oil indicates an excessively rich condition. To correct, you will need to drain the petrol contaminated oil and replace with new. Then, take out the old spark plug and leave the spark plug hole open. Turn the engine over several timesby hand to help vent any raw gas in the cylinder. Then, install a new spark plug.
You should be able to now start your engine and make any other adjustments with it running.
Cheers!
Dr of Motors
Mar 20, 2009 | Garden
Husqvarna 160 CC Honda OHC Engine 21 in Logo
556 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
