K toner low, wont go off
K toner is on all the time, opened compartment to change, but at the front is the cyan cartridge is this right
  • sales458 Jul 15, 2009
    Hi, thanks for the info, the printer is an Epson AL-C1100, it is still staying k toner low, but when i open the fron compartment, the cartidge is the cyan
  • 184 Answers
What version and make of printer are you using? the k toner should be the black toner. usually, the toner trays are color coded. check and make sure they are rightly placed.
Posted on Jul 15, 2009
Take out the Developer unit below the top cover, then you can rotate the unit that all 4 toners sit in until you can just slide out the Black, there is a silver strip that sits across the width of the printer I suggest you place the black to the back ( after the strip ) to remove rather than the front ( before the strip ) its just easier that way.
Posted on Nov 27, 2009
"009-362 Printer, Restart Printer, Reseat c cart., contact support"
The Cyan Toner Cartridge is either not seated correctly or the cartridge is bad. Open the front of the printer, pull out the Cyan Toner Cartridge, reseat making sure it fits all the way to the back.
If the problem is not resolved replace the Cyan Toner Cartridge.
Oct 21, 2010 | Dell Printers:Dell MFP Color Laser 3115cn
Have a c1900 but no disk for utility management to change toner cartridges, how do I get around this and change toner cartridges? Drivers are installed and printer in operation hence need to change...
You go through the menus :
Press Right arrow once,
Then down arrow 5 times (to Reset Menu)
The Down arrow 5 times to Change toner C (Cyan)
Then down arrow again to Change toner M (Magenta)
Then down arrow again to Change toner Y (Yellow)
Then down arrow again to Change toner k (Black)
Select your colour to change and press the right arrow. The engine durns, open the door and remove the cartridge
Jul 01, 2010 | Epson AcuLaser C1900 Printer
My 3000cn ran out of black and cyan toner, so I
I have fixed this now using advice that I found from other users on this site who had posted similar questions. In case it's useful to any of you, pull open the front cover and operate the small blue lever that you'll find behind it on the right. This opens a secret compartment on the outside of the printer and there you will find the cleaning rod. Pull and push this in and out about 15 times and it should fix any problems like the one I had.
Jan 28, 2010 | Dell 3000cn Laser Printer
Toshiba e-studio 280
Go into 'User Functions'
In there somewhere will be an option to replace the toner, press the cyan toner symbol and open and close the front door, the 'enter button' will be able to be pressed.. press enter and you should be ok..
Oct 08, 2009 | Toshiba E-Studio 3511 Color Copier
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
17H Service Required
Please follow the solution in the link below. Also as you putting in the cartridge always check for loose toner in the area and on the cartridge itself as this can block the sensors.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=74,E=0000000001343666831,K=8485,Sxi=0,Case=obj(3510)
Niallbt
Mar 29, 2009 | Xerox Phaser™ 6115MFP/D All-In-One Printer
Changing a cartridge C1100
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate Toner it will rotate to offer the correct toner. Open up the front cover, reach inside and change the position of the coloured part of the cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out first. Put the new toner in and turn the coloured part to the locked symbol.
Please take a moment to rate this solution, thanks.
Mar 24, 2009 | Epson Aculaser C1100 Printer
Cyan toner does not rotate to front to be change
um... Cyan is blue isn't it?
Magenta Pink,
Yellow = Yellow and
Black = black.
Oct 02, 2008 | Dell 3010cn Laser Printer
K toner low
C - is for Cyan
M - is for Magenta
Y - is for Yellow
K - is for BlacK
Jan 25, 2008 | Epson Aculaser C1100 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
97 people viewed this question
jasbo
jasbo
