Question about Copystar CS-1500 Copier
Error c-6 keeps appearing
How can i fix this problem on the 1500 copier? c-6 error
  • 40 Answers
Codes that start with c6 are caused by a problem in the heater. blown thermal fuse,
or bad heater lamp. you can access from the rear of the machine
Posted on Jul 23, 2009
E007-9901. already change new fixing but the same error code keep appear.. help me :(
what driver does it use ? can you print a configuration page from the device and compare the printer languages used. Example PCL 6 , PS . Is the driver matching the accepted languages the printer requires.
Jan 02, 2015 | Canon iRC4580i
Getting error messege E07
KM-1500 E-07 error
"E07" appears on the copy quantity / magnification display, The size of paper registered in the default settings is different than the size of the paper actually used. Check the paper size. Pull out the corresponding drawer and then push it back in to delete the error indications.
Sep 09, 2011 | Copystar CS-1500 Copier
Error - 5100 and 6A00 keep appearing. What should I do?
Error 5100 means an error occurred in the carriage encoder signal. Error 6A00 means an error occurred in the AP motor during purging operation. To fix these two errors you need to replace:
- Carriage unit (QM2-2922)
- Timing **** strip film (QC1-6394)
- Logic board ***'y (QM2-3078)
Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM
information print). If the waste ink amount is 7% or more, also replace the ink absorber kit (QY5-0146) when
replacing the logic board ***'y.
- Carriage motor (QK1-1500)
-Sheet feed unit (QM2-2916)
-Purge unit (QM2-2925)
Feb 02, 2011 | Canon Office Equipment & Supplies
Kyocera Mita KM-1500 shows flashing c-6 and 020 Pls help
check the fixing unit thermoswitch,thermistor & heaterlamp one of them is the cause of error
Nov 22, 2010 | Kyocera Mita Office Equipment & Supplies
I HAVE A CODE C-6 ON COPIER AFTER POWER WENT OUT
have a copystar#GS-1500 and after power went out, have flashing error code C-6 and 400. Worked perfect just prior. please help!
Oct 13, 2010 | Copystar CS-1500 Copier
After a power surge, the machine is flashing 400 and C-6. Unable to reset it.
if you are unable to reset the error using simulation U163 remove the fixing unit and check the continuity of the heater lamps and thermostat. if lamps ok. replace thermostat
Aug 09, 2010 | Copystar CS-1500 Copier
I'm getting c-6 400 code
This is a fixing error.But it can be caused by a power dip aswell.
Try to reset it,if the error presist then there is a problem on the fixing.
To reset-Switch the machine off,open the front cover,switch the machine on again.If it shows "open cover",press the system menu counter button.press the arrow up ones to display system settings,hold the start and # button in and press "ok"or"set"
go down with the arrows untill maintenance mode is display,press ok,then enter the number 163 and press ok.
set it for exeuteand press ok.
Then the error will be cleared.
Jan 22, 2009 | Copystar CS-1500 Copier
C6 error
Error C-6 appears on photocopier
Nov 06, 2008 | Copystar CS-1500 Copier
Error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Mar 02, 2008 | Kyocera KM-1505 Copier
Copystar CS-1500 Copier Logo
257 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
