Question about Garmin GPS
My screen went black. Worked the night before.
Turned on my Garmin GPSMAP 172C and the screen stayed black. The side buttons lit up ok. I noticed the last time I used it that the screen was getting dark.
  • 744 Answers
Hi..
when the unit is on try to press and hold the reset button for 10 seconds and then release if this will not work charge the unit for 3 to 4 hours using a wall adapter and if still not work try to check if there is a latest firmware update for the gps then download it.
thank u
rate me!!
Posted on Jul 15, 2009
Garmin GPSMAP 172C - cannot find satellites (WAAS)?
WAAS is a seperate service from GPS. It provides GPS corrections so if you can not get WAAS there is no big problems. you unit just wont be as accurate as normal. WAAS only is for North America and EGNOS for Europe. You may want to turn WAAS off for now. I suggest trying a update for the unit. You will need a memory card and Garmin USB programmer. Then just go to garmins site to get the latest update. If you need a USB programmer feel free to Contact GPSCity.ca or GPSCity.com. They are the leading experts in Garmin GPS.
Jul 12, 2010 | Garmin GPSMAP 172C GPS Receiver
When i turn on my gpsmap 60 cx it never acquires the satellites,it stays on this screen.
I had this on my Tom-Tom once. I think I reset it using the poke-a-pen-in reset switch, turned it off, charged it up with USB cable, updated it from the site, then went outside with it and it then finally acquired.
Jun 05, 2010 | Garmin GPSMAP 60Cx GPS Receiver
GPSMap 172c Can not read Garmin Data Card
I have the Sounder 178C. It will only work with 128 Mb Cards (or smaller). It does not work with the 256Mb Cards - says "Reading Card" forever.
Per Gramin, I had to buy the 128 Mb card and DVD map update. Then program the card with a USB data programmer to make it work.
May 01, 2009 | Garmin GPSMAP 172C GPS Receiver
Unit shuts off after a minute or so
i have the same problem. i just read that it maybe a software rather than a hardware problem. updating the firmware will "Fix bug on Data Card Information page to prevent unit shutdown"
http://www8.garmin.com/support/download_details.jsp?id=431
...trying to locate a pc interface cable to install...
Mar 28, 2009 | Garmin GPSMAP 172C GPS Receiver
Antenna input shorted
contact garmin sounds like a defective unit
Mar 10, 2009 | Garmin GPSMAP 172C GPS Receiver
No satelite acquisition for garmin 172c
you need to go outside in an open area with no trees around and turn the garmin on untill it receives a sat connection it can take several minutes for it to find it
Dec 04, 2008 | Garmin GPSMAP 172C GPS Receiver
Display won't come up anymore
The power switch usually allows you to adjust the backlight with a short tap there should be a scroll bar, use the four way toggle up to increase the back light.
Jun 16, 2008 | Garmin GPSMAP 172C GPS Receiver
172 will not work after dropping
Have you solved the problem?
If not you shall check that the flexible cable to the screen is securely connected to the circuit board. Check also the other cables.
BR
SHALL@tdc.dk
Oct 21, 2007 | Garmin GPSMAP 172 GPS Receiver
GPS screen went blank
My problem exactly. Unit would start up, acquire satellites, then the screen would go blank with a single vertical line. Unit would not respond to buttons or even turn off. Unit works fine after I did the reset:
- w/unit OFF, press and hold QUIT+DOWN+MENU
- press and release the power button, release DOWN, keep holding QUIT+MENU for 5 seconds.
- unit prompts something like: "erase all data;" choose yes.
- you will lose waypoints, etc.
Go to the Garmin support area for details.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Search for: "How do I reset my gpsmap 76"
Oct 06, 2007 | Garmin GPSMAP 76 GPS Receiver
GPS Logo
426 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
