Question about Compaq Presario 700 470024-192 Notebook
Not ping I have Asus 945 intel chipset ,I connected 4 system in workgroup,3 system working properly ,One system not pinging,Packets sent but not received,I checked my cable & lan properties please help
  • Compaq Master
  • 32,281 Answers
Is this computer in the same workgroup as the other computers?
Does this computer have the same IP address range as the other computers?
Is the network card on this computer working and enabled (check device manager)?
Use ipconfig command from the DOS panel to check the IP settings on this computer. Also run ipconfig on the other working computers and compare the IP settings. Each computer's IP address should all be the same except for the last group of numbers, eg. 192.168.0.xxx
Get back to me if you still have problems.
Posted on Jul 28, 2009
Problem in my device TL-WA5210G or from network help me
please forward your access points configuration. how do you configured it ? which isp your using ?? and from which country ?
Apr 16, 2013 | NEW Asi Tp-Link Nt Tl-Wa5210G Outdoor...
I have installed dlink 1016 10/100 Switch I have two computers and one dsl router connected to this switch but i am facing slow internet problem. when i connect my pc directly with router it works fine...
you'll probably find the router is set up to ignore ping requests, most are by default, for better results, try pinging a website and compare the results both with and without the switch. The switch shouldn't make any noticable difference to your connections, I use one and there's not perceivable difference in performance.
Apr 19, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
Hello sir. my voice call is not working, You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal. every...
It is because your internet connection is not good stable or not good enough for making voice calls...
To check this, Click on Start >> RUN... Type CMD and click on OK.
In Command Prompt, type ping 4.2.2.2 (space after ping) and press enter
it will give you result like this:
C:\Users\abhishek.tripathi>ping 4.2.2.2
Pinging 4.2.2.2 with 32 bytes of data: Reply from 4.2.2.2: bytes=32 time=309ms TTL=57 Reply from 4.2.2.2: bytes=32 time=275ms TTL=57 Reply from 4.2.2.2: bytes=32 time=276ms TTL=57 Reply from 4.2.2.2: bytes=32 time=275ms TTL=57
Ping statistics for 4.2.2.2: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 275ms, Maximum = 309ms, Average = 283ms
If you get 4r replies, than your internet connection is fine. Is any of the line says "Request Time Out" then it is clearly a problem with your Internet Connection.
Apr 12, 2011 | Yahoo Messenger
My internet connection is on but it won't show on my acer mini laptop please help meplease please please
How do you know that the internet connection is on try to ping a website
ping www.google.com
and see if you are able to receive the 4 data packets sent. If yes then check for the other settings.
Jun 24, 2010 | Computers & Internet
My lan is not working properly? so what can ido for it????????
Ensure that LAN card Driver is Installed Properly.
Check Proper IP address is assigned. and workgroup is same in networked computer
Run PING Command to check connectivity to other machine.
If ping Reply is not showing then Re-Crimp Cable after verifying IP address, Workgroup are Correct.
Mar 23, 2010 | Computers & Internet
Have a D-Link EBR2310 How can I test it to see if the port to the to the computer is working? The port gren does not light.
You are saying you cannot connect through the router ... Change the ethernet cable and/or try other portson the router.
Does your computer connect to the WWW when you wire it directly? If it will work when connected directly then it should work through the router. That is your test.
Thanks for your interest in FixYa.com
Please vote
a
Dec 03, 2009 | Office Equipment & Supplies
I have the HERMO packard bell model. I can hardly access internet and the sound is not heard. Please hhelp
For internet
Resolution:
First check ipaddress
Click Start -run- type cmd hit enter for XP or Start -search-type cmd hit enter in Vista. On the DOS black screen after the blinking cursor type ipconfig hit enter check the ipaddress if are getting ipaddress other than (169........) it is proper ipaddress for e.g 147.14.48.478
Ping the default gateway e.g ping 147.11.445.478 if you are able to get packets send 4 received 4 loss zero is with Internet explorer or operating system.
If unable to ping or getting 169..... ipaddress . you are having static ip address
On the black screen at the blinking cursor type ipconfig /release hit enter
then type ipconfig /renew hit enter .check ip address
Ping default gateway then ping www.google.com if you are able to get packets send 4 received 4 loss 0. Try connect to internet using internet explorer or other browser. if still unable to connect then issue with firewall or antivirus or IE corruption .
Create new administrative account in XP and do MSconfig .Restart the system and logon to new account and try connecting to internet.
If issue persist might have to repair IE or operating system as it is software issue or virus issue.
You can connect a different computer if you have one and check internet.
If unable to get any ipaddress or still getting static ip address ,reset modem or check ethernet cable ,do a hard reset on the internet modem.Shutdown and restart computer and check ipaddress then try connecting to internet.
NO sound : Check the sound driver .Try reinstalling sound drivers
Aug 24, 2009 | Computers & Internet
NIC problem on Intel D101GGC
Ensure security and firewalls are turned off if incoming packets cannot be received. Are you pinging the pc at 127.0.0.1? Update the driver via the pc device manager or buy a new nic for around $10 these days.
Apr 19, 2009 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
